I tried out the new Dharma Beta, and Transparency doesn't seem to be an option, I'm suffering with PM3.HD for the moment. I'm wondering if you'd consider working up this branch? I want use the HDW accelerated feature.
Worked like a charm... Enjoying what I had, what I've got and what's to come.
Just hope I don't have to re-install it all each update, which I gather might be a real possibility.
PatK Wrote:Worked like a charm... Enjoying what I had, what I've got and what's to come.
With Tortoise all you have to do is 'right click'-SVN Update on skin.transparency folder...
Reasonable to assume it'll be available through the new add-on interface before long though, yes?
JohnKFisher Wrote:Reasonable to assume it'll be available through the new add-on interface before long though, yes?
correct. :-)
