2010-09-03, 05:07
Hey, just downloaded XBMC today thinking of switching from MediaPortal and like what I see other than a couple of small issues.
First I'd like to say I started with Dharma beta 1, after I couldn't get things working right I figured it was a beta issue so I switched to the latest stable release, still had the issues. So now I'm back to Dharma and posting here.
Here is my debug log (removed user directory), I am using XBMC on an active directory.
I have 2 distinct problems with scraping movies, one is specific to TMDB the other is with pretty much any other scraper.
First with any other scraper than TMDB no matter what settings I use it's pulling information in various languages and most titles are completely wrong.
With TMDB the titles it actually gets are usually correct given some odd ones (Wes Cravens New Nightmare is an example), however with several of the movies it just shows up blank in library mode no title, no year, no nothing. When I went over the debug log myself I don't actually see any errors relating to these movies (the movie I chose was Avatar). You can see the movies it did scrape were just grabbed again from the XML file (several reinstalls so a couple did stay), however there is no XML for the movies that are blank. If I try to refresh the data it gets the search right and pops up (for Avatar) as there are many titles. I choose the correct one and almost instantly it downloads and all the information is still blank.
Here is a screenshot of the movie library to show what I mean by blank:
P.S.
Sort of side problem/annoyance:
Scraping TV shows using TVDB isn't downloading some banners even though prefer posters is disabled. If I go manually select the banners are there and it is for some fairly big TV shows that do have banners (Big Bang Theory for example).
P.S.
