Full Version: asrock ion remote custom buttons
Hello,
Since I've reinstalled my xbmc with a new live cd from xbmcfreak there has been some change in the remote buttons. I'm missing the aspect ratio function when I press OK. I've found that I should be able to add this feature in the remote.xml file in the FullScreenVideo/Remote section of the xml. I've added <select>AspectRatio</select> since this is how it was in the previous version, but this does not seem to work. Not sure what I'm doing wrong..
- kick -
Still haven't found a solution.. Although I have found people with similar problems Sad
rm -f /home/xbmc/.xbmc/userdata/Lircmap.xml; rm -f /home/xbmc/.xbmc/userdata/keymaps/remote.xml
cd /home/xbmc/.xbmc/userdata ; wget http://dl.dropbox.com/u/4325533/XCI/Remote/Lircmap.xml
cd /home/xbmc/.xbmc/userdata/keymaps ; wget http://dl.dropbox.com/u/4325533/XCI/Remote/remote.xml
chown -R xbmc:xbmc /home/xbmc
Please note username and use sudo if not logged in as root.
You can examine files before replacing them, this is a alternative keymap for that remote
