My guess is you were previously using an SVN build (from somewhere other than an official nightly) which had a newer database version than is in Dharma, thus it can't read the database.
Depending on what version it is, it may be easy to fix. Alternatively, you could wait for beta2 which will up the Dharma database version to be the same as is in trunk.
This is a guess though, as mediafire is the spawn of the devil - use pastebin or similar so that we don't have to jump through hoops to help
Cheers,
Jonathan
Here is his log on pastebin.
http://pastebin.com/CeH6MvFk
I know he has gone to bed. I'm not positive but I believe he told me it was straight upgrade from Camelot.
I'd rather get it fixed if it's going to be a while for beta2..
Let me know what you need from me. Thanks for the help.
Quote:ERROR: SQL: SQL error or missing database
I'd delete it and start again.
I'd rather not lose all my watched status though.. If there is a way to fix it, or somehow save the watched status I would rather.
Thanks for the reply.
Something even more bizarre Tbird forgot to mention. If he goes to recently added movies, those movies do show up properly.
Ok, got this working (thanks to Kricker!!
I launched XBMC (Camelot version) and exported my working library.. I then imported that into a fresh install of Dharma.. All is good now!
