2010-09-09, 20:02
Hi
I am not sure if this error is caused by XBMC or by Tvheadend.
Tested with
Tvheadend 2.11 and svn-5322
XBMC Live 9.11 and XBMC Live Dharma Beta1
I have searched the forum/wiki/trac/bug reports and found a few entries regarding channel sorting, but none of them really described the problem I had.
(1 2 3)
Since I am not sure whether this is a XBMC or Tvheadend bug, according to "HOW-TO submit a proper Bug Report" I should post here in the forum to clarify this before submitting a bug report.
Howto reproduce the problem (on my system):
Add a htsp Tvheadend source (in my case htps://192.168.112.139:9982)
Browse to the htsp source. Then a list of channels are displayed in a certain order. Now when I select a channel and (most of the times) come back to the channel selection screen (by pressing "x" or "TAB" on the keyboard) the channels are displayed in a different order.
I then gave a few channels a specific channel number ( for example 1 to 11 see screenshot TVheadend settings 1 ) and then tried again. In the first XBMC screenshot you will see that the channel sorting is correct from 1 to 11.
I then select channel number 1 (Hitradio OE3), then I press "TAB" and then I see that the channel sorting is wrong (XBMC screenshot 2). You see in the XBMC screenshot number 2 that channel number 1 is now channel number 265.
I noticed this in the debug log:
19:20:21 T:3077838720 M:1976586240 DEBUG: CPlayerCoreFactory::GetPlayers(htsp://192.168.112.139:9982/tags/34/265.ts)
I don't think it is a coinsidense that the transport stream 265.ts is afterwards channel number 265 of the channel I selected instead of channel number 1 .....
I don't understand why, but through this behaviour the CH+ and CH- keys on my remote control (pgUP and pgDOWN on the keyboard) will always select the "wrong channels" because of the channel sorting is always changing.
XBMC 1 Channels sorting OK http://tinypic.com/r/19piqv/7
XBMC 2 Channels wrong sorting http://tinypic.com/r/2v9dv1x/7
Tvheadend settings 1 http://tinypic.com/r/xfqge9/7
Tvheadend settings 2 http://tinypic.com/r/al2khu/7
I disabled all Tvheadend features such as "monitor signal quality" as I have read in the forum that this could cause problems, but it didn't help.
Here are my debug log files of XBMC and Tvheadend. I enabled debug logging in XBMC, stopped xbmc via service xbmc-live stop, emptied the log file, and then started XBMC via service xbmc-live start and then reproduced the channel sorting "problem". Same with Tvheadend.
XBMC debug log http://pastebin.com/zbvmx5PZ
Tvheadend debug log http://pastebin.com/7eY1zYhc
Hope that anybody could give me a hint. Please also let me know if this is related to Tvheadend, so that I could file a bug report there, if this really is a bug.
Thanks for any help!
Tested with
(1 2 3)
