@x23
What dieharder did is starting xbmc by hitting the wol button, not the xbmc machine!
That is, if your htpc is up and running, but xbmc isn't (maybe because you use the htpc for other stuff too), xbmc commander will think the htpc is offline and present the wol button. Dieharders script will then allow to startup xbmc remotely by hitting that button
n3IVI0
I'm still in progress of investigating chads issue.
At the moment i suspect that the request for the movie list times out.
I've got a timeout of 10s for the request, but it seems that chads machine takes longer than that to return the movie list.
Which is actually quite odd, because i'm getting the response for an equally sized library within fractions of a second.
So the problem would be on xbmcs side. Don't know whats going on there, maybe its a bug thats been introduced in a recent nightly.
Anyway: I've submitted an update to apple a few minutes ago, that will (amogst others) increase the timeout to 60s.
While this doesn't solve the slow request, it should at least make the movies reappear in the app.
misteriks
Biggest problem with your request will be figuring out where to put the button and how to call it
Seriously: I already query for the trailer url. Sending a "play" command to xbmc isn't a problem. I'll try to think of a way to add this.
@clock2113
All my banners show up fine when offline.
Just to be sure: Your banners are shown when online?
jackmeehan
I've requested support for an url scheme (thus allowing me to link "deep" into their app - like i do with imdb) from the developers of airvideo, but they wouldn't add that for security reasons.
