Hey Mcborzu might be a stupid question but i am having difficulty editing my dialogprogress.xml how do you keep it up long enough to edit it i am editing all the little menus now but the dialogprogress pops up for about a second then disappears so its hard to see what i have changed
One thing I do is code that up in that Volume .xml use using some dummy 'hello world' labels cause thats quick and easy to pull up. Then when I like the spacing and what not I switch it over to whatever .xml its supposed to be in.
Be careful on the id's, make sure you have or switch them over for the corresponding .xml. 2x check Confluence for that...
yeah thats kind of what i started doing in the end thanks for your help mcborzu
