Full Version: [Bug][Win] Blank screen when playing x264
Running Dharma beta 2:
When playing x264 material, the screen is blank. There is sound.
Pressing tab so the files are visiable the background isnt blank anymore, the film is now visible.
Pressing tab again to exit the "fil menu" turns the screen blank. Really odd.
The behavior is the same if I run XBMC in a wondow ( just alt tab it).
:confused2:
I have tried nightly builds too.
I have the exact same problem with DXVA enabled. Did you find a fix for this?
EDIT: Solved by installing latest ATI drivers.
