Looking at picking up an older computer for cheap. Just want to make sure it's enough for XBMC. Just need 720p. Here are the basic specs:
Pentium 4 Processor 2.8 GHz with HT
RAM 1024 MB or 1 GB ddr2
Any idea what the graphics card is? onboard?
yeah some onboard intel something. I will probably pick up a cheap pci card for it. Just need VGA anyhow.
Does it have a PCI-E interface? if so a £30 nVidia GT210 will play everything......
No, it just has a PCI-E x1 and PCI. So not so sure about it now.
virgahyatt Wrote:No, it just has a PCI-E x1 and PCI. So not so sure about it now.
Hmmm I'm sure I read somewhere you can buy an ION GPU on a PCI-E x1 card... I'll have another look....
Isn't the Broadcomm crystal HD card PCIe x1? XBMC supports that card... wonder if that is an option in combination with onboard intel craphics?
That card is fine - I had that exact one in P4 machine and 1080 was no problem with a Live install.. that was before DXVA for windows was running so you should be good across all platforms now...
Cool thanks guys. Getting the rig for $75 with win xp. So hopefully will work for a really cheap htpc for the guest bedroom
Perfect timing, as the XBMC Live Dharma Beta 2 will hit the servers soon I think....
