2010-09-15, 23:13
As a result of my efforts to create an Addon Dev guide see http://trac.xbmc.org/ticket/10107
I've released an initial gPodder integration addon.
Please note;
I developed this under dharma (V10 beta) of XBMC
You need to install gPodder first on your server
You need to read the README.TXT contained in the addon directory
See http://forum.xbmc.org/showthread.php?tid=80476 for how to install/run gPodder updates in a cron (Linux systems) and generally how to make gPodder play in your network (implied)
This is an alpha release - report all all issues in the issue tracker at google, not here at XBMC (you will probably need a Google account to do that but I'm not sure - it's free anyway.)
Download the zip file at:
http://code.google.com/p/xbmc-gpodder-in...loads/list
If this makes it through Alpha, I'll submit to XBMC official repositories
Cheers
Ashley
Please note;
Cheers
Ashley
