Does anyone know how to change the amount of time it takes for the internal player (dvdplayer) to set a movie to "WATCHED"
I know if I use an external player I can set the <playcountminimumtime> but what about the internal player, where and what do I set for the internal player to?
Thanks,
add this line to advancedsettings.xml
<playcountminimumpercent>90</playcountminimumpercent> <!--Minimum percentage that has to be played before it is marked as watched -->
search the wiki for it
The_Dogg Wrote:add this line to advancedsettings.xml
I added this line to my advancedsettings.xml and it does not set the movie to WATCHED after the specified time what am I doind wrong?
<advancedsettings>
<video>
<playcountminimumpercent>50</playcountminimumpercent>
</video>
</advancedsettings>
It's a percent, as stated in the name of the entry. So, at your setting, it'll set it to watched after having completed 50%.
YodaEXE Wrote:It's a percent, as stated in the name of the entry. So, at your setting, it'll set it to watched after having completed 50%.
Problem solved. I was launching the wrong .exe I needed to launch the XBMC (portal).
Thanks for your Help guys
