Hello guys,
Im quite excited to find this Transparency skin... it seems to be just what I want in a skin...
ive downloaded it and put the Transparency! folder in C:\Users\mark\AppData\Roaming\XBMC\skin but it does not show in xbmc when I restart the app...
any ideas why? I am running xbmc-r33778-Dharma_beta2
Mark.
You must put it in C:\Users\mark\AppData\Roaming\XBMC\addons and name the folder skin.transparency...
Skins are now addons
Cheers
Hi nuzela, thanks for the repsonse, but
the folder is
C:\Users\mark\AppData\Roaming\XBMC\addons\skin.Transparency!
as you say, but it does not show in the Settings>Appearance>Skin
What else to try?
Mark.
What version of T! are you using?
nuzela10 Wrote:What version of T! are you using?
Hi
v2.11... downloaded from the developer's site last night..
Just as a test, I installed another skin (this time via xbmc settings and not as a download) and that skin shows up, and is installed in a different folder:
C:\Users\mark\AppData\XBMC\addons
I copied and pasted the folder skin.Transparency! to that addons folder but it still does not show up...
I wonder if this skin is not compatible with Dharma_beta2? I see the developer page talks about it being compatible with a more recent SVN version (i have no idea what that is, and was hoping on NOT having to spend hours trying to add a skin...)
Tx
Mark.
nuzela10 Wrote:v2.11 doesn't work with Dharma...you have to download the latest version from svn...
...or from this link --> http://passion-xbmc.org/downloads/?sa=downfile;id=91
...unpack it, rename to skin.transparency and put it in addons folder
THAT WORKED!
Thanks mate, your help and commitment is much appreciated.
Cheers
Mark.
