2010-09-17, 15:52
Hi there,
I'm currently using the XBMCfreak live CD Beta 2 from http://www.xbmcfreak.nl. I used this tutorial on howto install the remote for the Dharma Beta releases on http://forum.xbmcfreak.nl/topic/howto-as...8-svn32696.
That tutorial only worked for the Dharma Beta 1 release, but for the Beta 2 it doesn't seem to work at all. At the end of the install of the lirc drivers it seems that it cannot start the lirc driver because it says "starting deamon: fail".
I don't know whats wrong so if anyone could help me out would be great!
EDIT: Here's one my ouput when trying to follow this method: http://forum.xbmcfreak.nl/topic/howto-as...8-svn32696
Thanks in advance,
Fjerpje
xbmc@XBMCLive:/tmp/lirc/lirc-nct677x-1.0.4-buntu10.04_kernel2.6.32-23$ sudo dpkg -i lirc-nct677x-1.0.4-ubuntu10.04_kernel2.6.32-23.deb
Selecting previously deselected package lirc-nct677x.
(Reading database ... 58501 files and directories currently installed.)
Unpacking lirc-nct677x (from lirc-nct677x-1.0.4-ubuntu10.04_kernel2.6.32-23.deb) ...
Setting up lirc-nct677x (1.0.4-ubuntu10.04_kernel2.6.32-23) ...
Copy patch file...
/usr/share/lirc_wb677/lirc_wb677.ko' ->/lib/modules/2.6.32-25-generic/kernel/ubuntu/lirc/lirc_wb677/lirc_wb677.ko'
/etc/lirc/lircrc not existed. copy it directly.
patching file /usr/share/lirc/lirc.hwdb
* Stopping execution daemon: irexec [fail]
* Starting execution daemon: irexec [fail]
(Reading database ... 58507 files and directories currently installed.)
Preparing to replace lirc-nct677x 1.0.4-ubuntu10.04_kernel2.6.32-23 (using lirc-nct677x-1.0.4-ubuntu10.04_kernel2.6.32-23.deb) ...
ERROR: Module lirc_wb677 does not exist in /proc/modules
Reconfigure lirc
Unpacking replacement lirc-nct677x ...
Copy patch file...
/etc/lirc/lircrc existed. append it.
* Loading LIRC modules [ OK ]
* Unable to load LIRC kernel modules. Verify your
* selected kernel modules in /etc/lirc/hardware.conf
Thanks in advance,
Fjerpje
