Full Version: Oops, cant install XBMC
I came back from work today and decided to install the Dharma branch, I had issues wuth the packages being held back so, after googling my proble I did a dist-upgrade which has now removed my previous copy of XBMC and my Mrs is now going to kill me.
When I try to install XBMC I get this:
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies.
xbmc: Depends: xbmc-data (= 2:10.00~svn33778-karmic1) but 1:9.11-karmic3 is to be installed
Depends: xbmc-skin-confluence (= 2:10.00~svn33778-karmic1) but 1:9.11-karmic3 is to be installed
E: Broken packages
Please help.
Obviously it's trying to install the wrong version of the confluence skin and data, anyone know how to fix this?
It's ok I fixed this by removing all of my software sources and re-adding the ones I wanted.
