Full Version: (Linux) How to install greek language through command line?
Hi
How can i install greek language through terminal? Basically i need greek language support for xbmc to be able to read my file names correctly.Now my media file names looks very weird .
You've set your locale/country settings to Greek already within Xbmc?
You're not specifying which Linux version you're using, which makes it very hard for people to tell you how to set your locale exactly on Linux (different distros = different tools).
A quick look at the Trac reveals there is a fully functional Greek Xbmc translation, so the issue is probably with your setup. Make sure your Linux installation uses/supports UTF-8, I think that's the first step.
