2010-09-19, 15:28
Hi XBMC friends,
I have installed XBMC-live under Ubuntu 10.04 (64bit), it runs on a Zotac Ion board.
No problems to play video and music from my Music and Video share (smb share on Ubuntu Server)
But I run into trouble when using the m3u playlists that are also on my Server.
Original playlists on the server look like this:
The Original Playlists are stored on //JABBA/Musik/Wiedergabelisten.
Under XBMC I open this playlist and saved it to a different name.
XBMC is unable to play this imported playlist, the reason is clear, because XBMC converted it into this format.
It can’t find the files in the playlist…
Yes, I used the search function in this forum an found a hint to use the <pathsubstitution> function
In a file called “advancedsettings.xml” in ~/.xbmc/userdata$
I created it with this entries:
Unfortunately it doesn’t help, the behavior is still the same with or without this file.
Is there anybody who can help ?
Many regards
Guido
Version Information, not true if it is important:
Starting XBMC, Platform: GNU/Linux. Built on Aug 19 2010 (SVN:26018)
#EXTM3U
#EXTINF:0,Private Life (Long Version).mp3
\\JABBA\Musik\Grace Jones\Private Life (Long Version).mp3
#EXTINF:0,Beautiful Day.mp3
\\JABBA\Musik\U2\All That You Can't Leave Behind\Beautiful Day.mp3
#EXTINF:0,02 - Magnificent.mp3
\\JABBA\Musik\U2\No Line On The Horizon\02 - Magnificent.mp3
#EXTM3U
smb://JABBA/Musik/Wiedergabelisten///JABBA/Musik/Grace Jones/Private Life (Long Version).mp3
smb://JABBA/Musik/Wiedergabelisten///JABBA/Musik/U2/All That You Can't Leave Behind/Beautiful Day.mp3
<pathsubstitution>
<substitute>
<from>\\JABBA\Musik\</from>
<to>smb://JABBA/Musik/</to>
</substitute>
</pathsubstitution>
Many regards
Guido
