2010-09-19, 20:18
i've following configuration problem.
I'd like to have following behavior in fullscreen tv but i'm not able to set the remote.xml correct.
1. In fullscreen tv with "select" key open the channel list (works with <select>XBMC.ActivateWindow(PVROSDChannels)</select>) and then select a channels with "select" key and close the pvrosdchannels <-- cant figure out the close after the select with no additional key
2. with the "guide" key of the remote it would be cool to open the epg timeline ... in the confluence skin dir i found that it is opened with
<description>TV Guide Timeline</description>
<visible>Control.IsVisible(10)</visible>
<-- Is it possible to set it also to a remote key? Is it possible to jump to the current channel?
Maybe someone can help me.
thx vts
thx vts
