Question goes like the title:
How can I set default movie box to Blu Ray instead of DVD?
I know it gets updated when the movie has played and therefore xbmc knows video resolution. I'd like to set default view to Blu Ray boxes.
How can I achieve this?
xbmc will detect the video resolution as soon as you add your movies to the library, so there's really no need to play them first.
(Settings > Videos > File lists > Extract thumbnails and video information)
there's no easy way to set the default case to blu-ray.
it would take a lot of code changes in many files.
ronie Wrote:xbmc will detect the video resolution as soon as you add your movies to the library, so there's really no need to play them first.
Oh great, that did the trick.
I regret the 150 movies I was starting/stopping so far ...
I had to disable that option "Extract thumbnails and video information" in the past, don't know why anymore. But I do now what it does now.
You're the best, thank you very much!
What version of transparancy did this feature become available with (Dharma Only?)
Darby Wrote:What version of transparancy did this feature become available with (Dharma Only?)
the DVD/Blu-Ray cases ?
it's in the T! svn...Dharma only yep :-)
ronie Wrote:there's no easy way to set the default case to blu-ray.
Or change the images that !T uses for dvd's to the ones that uses for BR's.
