Full Version: [MOD] Rapier [MikotoBuild] (for Dharma)
Pages: 1 2 3 4 5
Direct Download [v2.0.3] (updated:03/03/11 11:38mst):
Click Here to Download Manual Zip
Also available on the: Passion-XBMC.org Repo
Please any suggestions, requests or bug reports can be submitted here.
To install this Mod, simply upload it to your xbmc directory, and use the "Install From Zip File" option in the Dharma Addons main menu.
Change Log
v2.0.3
Fixed issue scrolling with mouse wheel in "List Info" view.
(Fix provided by tbob19 @ forum.xbmc.org)
v2.0.2
Fixed submenu issue.
RMB v2.0.1
Fixed Brazilian Focus Image
Temporary fix -- Sort Method
RMB v2.0.0
Repaired Music category primary item
Repaired Home Menu > settings > skin
Repaired Video Info background
RMB v1.1.5
Added Support for Addon Configuration
Added Support for Addon Changelog
RMB v1.1.4
Repaired functionality of addon browser
Graphical fixes for addon browser
RMB v1.1.2
Reworked Home Screen With New Multi-Icon System
Added New Control File - Includes_MenuIcons.xml
Added New Control option in skin settings > Home (Show Icon Settings)
Created new Icon Settings Control group (Skin settings > home)
Added options to select new icon or original rapier icon in each category
Integrated custom icons into the new control scheme
Added preview for each icon in skin settings
RMB v1.1.1
New Icons
RMB v1.1.0
Cleaned up unused code
Reworked Main menu scrolling animation
Removed Skin Settings made obsolete by new home menu system
Incorporated "Recently Added" script found in Qualar's Mod (Requested)
Fixed duplicate window ID in addon browser (may have caused isolated issues with loading page)
Added code to skin settings to disable recently added box
Realigned Home Menu Icons
Reworked Home Menu Sub Menus to better display all items
RMB v1.0.4
Reworked main menu to use submenus (press up)
RMB v1.0.3
Fixed Scrollbar in Movies Wall View
Added Scrollbar to Movies Wall View 2
Added Hide Scrollbar options in Movies Wall View 2
RMB v1.0.2
Fixed keyboard/remote navigation issue in library view.
RMB v1.0.1
(Request) Added secondary wall view for movie library with movie information always enabled.
RMB v1.0.0
addon support (Settings > Add-ons)
System Category now enters directly into the settings.
Skin settings have been moved. (Settings > Skin Settings)
Following items have been relocated to the General Category: Profiles, System Info, Credits.
This mod also adds HD Movies category to the home menu (uses a smart play list for resolution based filtering. This Category can be disabled in the skin settings.
Thank you for this wonderful skin, subtitle plugin is working fine, I tested it on latest Dharma. Great work.
I'm only missing from Qualar mod, the ability in the home screen to go directly from any selection to it's sub-directory like in "Movies" with the upper arrow to go to Recently added, gener, actors, year, etc...
If this option can be integrated, that will be very nice.
thanks again.
I just noticed that while troubleshooting a missing item from my wall modes.
I can add such a feature once I've solved my current problem.
Update: Request Filled
I just installed your skin and it looks great. I like the improvements a lot, but am really missing the 'last added' feature. After adding new movies I always use this feature to inspect my latest additions.
I do hope you like this suggestion and I'll be seeing it incorporated in a future build.
Thank you very much. perfect. Why does it only see 1080p movies in the new category HD MOVIES and no 720p??
Addons doesn't work for me at all...anyone else with this problem?
#jz1276
720p shows up fine here...
As for the 720p issue. That's just an xbmc smart playlist doing resolution sorting. I tested it on my own library and it works fine. For some reason your 720p movies may not be passing the resolution check which would cause it not to show them. Nothing that could be done to fix that unfortuneately.
As for the addons not working..... what OS is this running on? Which Dharma Beta?
Windows 7 professional 32bit, Dharma Beta 2..
When using Confluence it's not a problem...
@Matteius: you're not adding the 'last added' function?
I don't understand the other request. The 'up key' was already working in 1.03.
I'm now looking if I can see a difference between the 1.03 and 1.04, but can't spot it.
@frater: I should have mentioned that I am planning to add the requested latest added function, but it will take a bit of time. And the up butoon submenu navigation wasn't added until 1.0.4... I should know, took me a good half a day to work out how to get that to properly function while still looking decent ^_^
@bblauritzen: I've tested on windows 7 x64 and on linux builds of dharma beta 2 and both work... however I shall go through the code for the addon page and see if I can spot any problems that could be affecting it. If I spot anything I'll PM you to see if you can test if it's fixed.
@frater: your request is filled as of 1.1.0... enojy ^_^
Matteius Wrote:@frater: your request is filled as of 1.1.0... enojy ^_^
Very much appreciated... Now I can make the switch from Qualar to Mikoto.
No requests for a while Wink
Thanks..
So far this is great...I like the HD movies feature...thanks...I will be using this! Great job!
bblauritzen Wrote:Addons doesn't work for me at all...anyone else with this problem?
#jz1276
SAme here. Heres a link to my post where I put a link of the debugg log with my add-on problem I hope this can be fixed as this is my favorite skin.
http://forum.xbmc.org/showthread.php?tid=82197
Pages: 1 2 3 4 5
