2010-09-23, 23:06
Hi there,
i already got xbmc running, once ^^, and i think i ve used the exactly same config, but now i allways do get the error message :"xbmc need hardware accelerated OpenGL rendering driver error"
i have a ati radeon HD5750, installed the properitary driver from the ati page (version 10-9)
fglrx info shows:
alltough, i think the driver is running well, because, vlc can play fullHD, and i do have sound over hdmi,
to xbmc :
is used de build-deps from
https://edge.launchpad.net/~team-xbmc-svn/+archive/ppa
and build xbmc from the git repository,
at first i had a strange error
make, and afterwards make install, and no error occured,
between, i use ubuntu lucid 10.04 desktop
i hope i gave you enough information, and sorry for my bad english ;-)
kind regards, bonomat
fglrx info shows:
Quote:opengl rvendor string: ATI Tech...i am not sure if here is allready the problem, because i think, last time there was another OpenGL version string, like 3.x or something,
OpenGL render string :A ATI Radeon HD 5700 Series
OpenGL version string : 1.4 ( 4.0.10188 compatibility profile context)
to xbmc :
Quote:sudo make installbut then i tried first
Copying XBMC binary to /usr/local/lib/xbmc/xbmc.bin
install: cannot stat `xbmc.bin': No such file or directory
make: *** [install-binaries] Error 1
