So, I've done a couple tweaks to XBMC. The 2 that are relevant here are that I added logos to the show pages, along with increasing the font size slightly to make it a bit easier to read at a distance.
The thing is, I need to lower the listing a little bit, because with the new font size the logos tend to overlap with the top item in the show listings. Here's a picture to show what I'm talking about:
So, does anyone know what I need to modify in order to shift the episode listing down a bit, so that it's not covered up?
Bump. Anyone got any info for me?
If you want to move down the whole list a little bit, just search the following code
<control type="list" id="504">
<posx>660</posx>
[b]<posy>60</posy>[/b]
<width>580</width>
<height>601</height>
<onleft>2</onleft>
<onright>60</onright>
<onup>504</onup>
<ondown>504</ondown>
<viewtype label="$LOCALIZE[544]">list</viewtype>
<pagecontrol>60</pagecontrol>
<scrolltime>200</scrolltime>
<visible>Container.Content(TVShows) | Container.Content(Movies) | Container.Content(Seasons) | Container.Content(Episodes)</visible>
and change <posy>60</posy> to <posy>80</posy> (just play with the number to find the right for you)
sonic00 Wrote:If you want to move down the whole list a little bit, just search the following code
<posx>660</posx>
<width>580</width>
<onleft>2</onleft>
<onup>504</onup>
That worked perfectly! Thanks a lot!
