I've got this working i can connect fine however when i reboot into xbmc it shows as disconnected then after a minute or two it will eventually pick up an ip address, anyone else get this or know what i might be doing wrong?
You don't need to reboot to get back to xbmc. IIRC the keyboard shortcut is CTRL, ALT AND F7 to get back to XBMC (it's been a while so I might be wrong). If you do reboot then it's normal that it needs to reconnect again.
Yeah i see that it would need to reconnect after a reboot but it seems to be taking a long time before it would connect to the wireless.
