2010-09-25, 21:41
2010-09-25, 21:53
try <zorder>3</zorder> near the top like underneath default control in the OSD script .xml...
2010-09-25, 21:54
mcborzu Wrote:try <zorder>3</zorder> near the top like underneath default control...
Negative. Any other ideas?
2010-09-26, 01:16
Maybe try and attach the script to the music OSD dialog instead of the music visualization window.
2010-09-26, 04:22
igotdvds Wrote:Negative. Any other ideas?
<zorder> for both osd and lyrics window (3 and 2 for example)
2010-09-26, 05:33
xbmchead Wrote:Maybe try and attach the script to the music OSD dialog instead of the music visualization window.
It is attached to the musicosd.
phil65 Wrote:<zorder> for both osd and lyrics window (3 and 2 for example)
How would I change anything on the lyrics window. Its running the script which means I cant change it.
2010-09-26, 05:39
igotdvds Wrote:It is attached to the musicosd.you can. by adding a script-XBMC_Lyrics-main.xml to your 720p folder (you can see which control ids you have to use in addons/script.cu.lyrics/resources/skins/Default/720p/ )
the same works for other scripts, too.
