Full Version: jumper pin thinggy
putting in a 40g hdd ide
do i need the jumper pin thinggy
the stock xbox hdd has one
should i use that on new hdd?
TA
-- Sun Sep 26, 2010 4:53 pm --
any one i have hdd in my hand and want to put it back inHuh
ummmm the hard drive should tell you on the back if it needs a jumper and what pins it needs to be on.
-=Jason=-
Flomaster Wrote:ummmm the hard drive should tell you on the back if it needs a jumper and what pins it needs to be on.
-=Jason=-
i cant tell there is no sticker on the hhd old 2nd hand one
all i know is the stock xbox one has it
im sure some smart guy know the solution
Try asking on http://xbmc4xbox.org/
JR
