Full Version: Bug script/addon add as a item selected from favourites
I would think this not Transparency related but I don't know where else to place this topic.
Settings > skin Settings > Menu
I add a script/addon as a item and select from favourites the script/addon.
Some script/addon items don't want to load. Than I looked at favourites.xml.
And I saw that it is different than items that do load correctly. I would think that is the problem somehow?
RunScript("script.navi-x") < work correctly
RunScript("script.games.rom.collection.browser") ''
RunScript("net.rieter.xot") < doesn't want to load
RunScript("xbmc.site.helper") ''
tikkiew Wrote:RunScript("net.rieter.xot") < doesn't want to load
known issue with xoz:
http://forum.xbmc.org/showthread.php?tid=25522&page=77
tikkiew Wrote:xbmc.site.helper
never heard of that one...where can i download it?
for the time being, you can rename the folder
net.rieter.xot/recources/skin.confluence
to
net.rieter.xot/recources/skin.transparency
and the script will run.
Actually I don't want to add XBMC Helper as a item
I got it from Passion-XBMC Add-on Repository
I use it to figure out why I had problems with XOT-UZG
Thanks for helping. I will try your solution.
ronie Wrote:known issue with xoz:
It seems to me that this is another issue. I can run XOT-UZG addon with the skin transparency!. But XOT-UZG and XBMC.Helper don't want to run if you make it a item. As I said in the first reply. Your solution didn't change this.
got it, thanx!
it's a bug in script.favourites that's used by several skins (including T!)
to add favourites to the home menu.
i'll see if i can get this fixed.
