2010-09-28, 15:25
danz0l Wrote:Hi smithr99 i tried the precompiled and it refuses to launch. Did you get it working ?
nope. was giving me segfaults when trying to load (see original thread post). no idea why!
smithr99 Wrote:nope. was giving me segfaults when trying to load (see original thread post). no idea why!
root@XBMCLive:/home/xbmc/mupen64plus/test# ./mupen64plus /mnt/1tb/Games/Consoles/N64/Roms/MarioKart\ 64.z64
__ __ __ _ _ ____ _
| \/ |_ _ _ __ ___ _ __ / /_ | || | | _ \| |_ _ ___
| |\/| | | | | '_ \ / _ \ '_ \| '_ \| || |_| |_) | | | | / __|
| | | | |_| | |_) | __/ | | | (_) |__ _| __/| | |_| \__ \
|_| |_|\__,_| .__/ \___|_| |_|\___/ |_| |_| |_|\__,_|___/
|_| http://code.google.com/p/mupen64plus/
Mupen64Plus Console User-Interface Version 1.99.3
UI-console: attached to core library 'Mupen64Plus Core' version 1.99.3
Includes support for Dynamic Recompiler.
Core Warning: Couldn't open configuration file '/root/.config/mupen64plus/mupen64plus.cfg'.
Using defaults.
Core: Goodname: Mario Kart 64 (U) [h1C]
Core: Name: Mario Kart 64
Core: MD5: 7D54D888964A3B0D058EB80886C44C88
Core: CRC: 3e5055b6 2e92da52
Core: Imagetype: .v64 (byteswapped)
Core: Rom size: 12582912 bytes (or 12 Mb or 96 Megabits)
Core: Version: 1446
Core: Manufacturer: Nintendo
Core: Country: USA
UI-Console: Cheat codes disabled.
UI-console: using Video plugin: 'Mupen64Plus OpenGL Video Plugin by Rice' v1.99.3
UI-console: using Audio plugin: 'Mupen64Plus SDL Audio Plugin' v1.99.3
UI-console: using Input plugin: 'Mupen64Plus SDL Input Plugin' v1.99.3
UI-console: using RSP plugin: 'Hacktarux/Azimer High-Level Emulation RSP Plugin' v1.99.3
init kbd.
Input Warning: No joysticks/controllers found
Input: Forcing keyboard input for N64 controller #1
Input: Using auto-configuration for device 'Keyboard'
Input: Mupen64Plus SDL Input Plugin version 1.99.3 initialized.
Video: SSE processing enabled.
Video: Found ROM 'Mario Kart 64', CRC b655503e52da922e-45
Video: Initializing OpenGL Device Context.
Core: Setting 32-bit video mode: 640x480
Core Error: SDL_SetVideoMode failed: OpenGL not available
Video Error: Failed to set 32-bit video mode: 640x480
Core Status: Rom closed.
smithr99 Wrote:i think this might be where we need to use the Glide64 video plugin for mupen, rather than opting for the Rice plugin by default
i seem to remember somewhere reading about it !!
EDIT: i changed the permissions on pretty much everything to do with mupen64plus to 0777 (bad habit, I know!) and am now at the stage where you're at (getting OpenGL errors)
I wonder if this is anything to do with the version of nvidia drivers I've got installed ?
Quote:xbmc@XBMCLive:~/mupen64plus$ sudo ./mupen64plus m64p_test_rom.v64
__ __ __ _ _ ____ _
Core: Goodname: Mupen64Plus Demo by Marshallh (GPL)
Core: Name: Mupen64Plus
Core: MD5: DBF04773EC2B8ADF8A94DB7E3E461138
Core: CRC: ddba4de5 b107004a
Core: Rom size: 1048576 bytes (or 1 Mb or 8 Megabits)
Core: Version: 1444
Core: Manufacturer: 0
Core: Country: Demo
init kbd.
UI-console: using Video plugin: 'Glide64' v1.99.3
Core Error: broken Video plugin; function(s) not found.
UI-Console: error from core while attaching Video plugin.
root@XBMCLive:/home/xbmc/mupen64plus/test# ./mupen64plus --gfx mupen64plus-video-glide64.so --resolution 1024x768 MarioKart64.z64
__ __ __ _ _ ____ _
Core: Version: 1446
Core: Country: USA
init kbd.
Input: N64 Controller #1: Forcing default keyboard configuration
Video: SSE detected.
Input: N64 Controller #1: Using keyboard/mouse
Input: 1 controller(s) found, 1 plugged in and usable in the emulator
Video: opening ./Glide64.ini
Video: fb_clear 0 fb_smart 0
Video: extensions 'CHROMARANGE TEXCHROMA TEXMIRROR PALETTE6666 FOGCOORD EVOODOO TEXTUREBUFFER TEXFMT'
Video: fb_hires
Core: Setting video mode: 1024x768
Video Error: Could not set video mode.
Video Error: Error setting display mode
Audio: Initializing SDL audio subsystem...
ALSA lib pcm.c:2211:(snd_pcm_open_noupdate) Unknown PCM remap-surround71
Audio Error: Couldn't open audio: No available audio device
Core Warning: OpenGL function glActiveTexture() not supported. OSD deactivated.
Core: Starting R4300 emulator: Dynamic Recompiler
Video: ucode = 1
Core: couldn't open eeprom file '/root/.local/share/mupen64plus/save/Mario Kart 64 (U) [h1C].eep' for reading
Core: couldn't open memory pack file '/root/.local/share/mupen64plus/save/Mario Kart 64 (U) [h1C].mpk' for reading
cd /path to mupen64v.199
xinit ./mupen64plus --fullscreen /path/to/rom
Quote:sudo service xbmc-live stop
