Full Version: Playing .mkv files
Hi all,
I just installed xbmc for linux. I am new to linux but not new to xbmc, have it on my xbox1.
I just recently built a HTPC, using ubuntu server 10.04. It has an H57 mobo with i3 cpu. I have an mkv file that i wanted to play but unfortunately the video doesn't start. I get a message saying, "Playback Failed".
I looked at the logs and this is what i found:
Quote:04:40:54 T:140661246363408 M:3513647104 ERROR: CDVDPlayer::OpenInputStream - error opening [/home/xbmc/Movies/some movie/Isome movie.mkv]
04:40:54 T:140661246363408 M:3513647104 NOTICE: CDVDPlayer::OnExit()
04:40:54 T:140661246363408 M:3513647104 NOTICE: CDVDPlayer::OnExit() deleting input stream
04:40:54 T:140661723772960 M:3513647104 ERROR: Playlist Player: skipping unplayable item: 0, path [/home/xbmc/Movies/Iron Man 2/Iron.Man.2.mkv]
04:40:54 T:140661118465808 M:3513495552 ERROR: InputStream: Error opening, /home/xbmc/Movies/some movie/some movie.mkv
04:40:54 T:140661723772960 M:3513495552 NOTICE: CDVDPlayer::CloseFile()
04:40:54 T:140661723772960 M:3513495552 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
04:40:54 T:140661723772960 M:3513495552 NOTICE: DVDPlayer: waiting for threads to exit
04:40:54 T:140661723772960 M:3513495552 NOTICE: DVDPlayer: finished waiting
I looked around but i couldn't get far. Some people said it worked for them, other said it didn't.
I am hoping i can find some answers if i post this issue here.
Thanks ahead of time for the help!
Can't say i can offer much help as all my .mkv files (my entire collection) play fine. You may want to check permissions on the folders those videos are in and make sure the user XBMC is running under can access those files.
Another thing to consider is file movement. If you have rearranged files lately, you may want to run the library cleanup. I had some files listed in library mode that moved or no longer existed but still showed up in the listings.
Best of Luck,
~NSW
