2010-10-01, 12:38
Morning All
A rather strange one here. I have a back end server running Ubuntu Karmic with two usb (yes, I know) external 1TB drives with media.These are set up as shares in samba. My samba install has aio set and is pretty rock solid for access.
My front end is a revo running karmic with xbmc (last final) and I've solved most of the issues with the box bar one.
The revo is hard ethernet connected to a switch that also connects to the server everything is fine for 100mb.
I've tested the file transfer speed in system file tool within xbmc for files and everything seems fine.
Now for the problem.
On playback of media I get glitches. These do not increase the dropped frame count but when I check in the log I find these
Now the REALLY weird thing is these start happening every 5 minutes, so I'll see one at 19:11, one at 19:16, one at 19:21 and so on.
I've checked my Samba log.nmbd file, log.kraken (the revo box) syslog and messages to see if anything coincides with these issues on the server side and I can't find anything.
I've done a similar exercise
On the revo and the only thing there is the wifi linux wpa_supplicant process reporting back but that happens every minute or so due to a bug in the process anyway.
Sooooo I'm a little stuck. Anyone got any ideas, happy to post a pastebin of any logs if it will be diagnosticly helpful. or am I up the wrong tree completely and a read error isnt file read but something else.
Also has anyone seen this issue before and is it fixed by dharma?
Many thanks all
Edz
Quote:19:11:26 T:2929863536 M:1151926272 ERROR: Read - Error( -1, 22, Invalid argument ) - Retrying
Quote:cd /var/log
sudo fgrep -yR 19:11 * | grep -y "sep 30"
Many thanks all
Edz
