Full Version: Logitech MX Air vs. Wii Remote
Hi everyone, I'm new here, but I've been researching the information here for several weeks now. I wanted to have an in-depth discussion about remotes. Currently, I am using the Logitech MX Air, and it's really great. The MX Air is the best airmouse on the market. There is only feature it is lacking: a directional pad. This is essential for programs like XBMC and any other frontend for HTPC's. Why is it essential? because a mouse is simply too accurate and freeform for something like navigating a huge screen with limited movement. it's great for precise movements that you need when you use a desktop pc, sitting 3 feet away and with tiny text and buttons everywhere. But for TV's, everything is better with a D-pad. That's why all dvd players and cable TV remotes have a D-pad at the heart of it's construction. There's always the up-down-left-right plus centered Enter button on every TV remote.
So, I'm looking for the perfect remote for use with XBMC. The only thing I could find was the Wii remote. It has the ability to be a mouse (with glovepie) but it also has the D-pad. The only problem with it is that I highly doubt it's mouse functionality is as nice as the MX Air. The MX Air is awesome in that it's very easy to control, and it has a really nice feature where it recenters itself when you go too far off screen or put the mouse down (something like that, I don't understand how the recentering works exactly, but it's very nice).
From what I've seen with the Wii remote, the movement is a little less pleasant. It's not as responsive as the MX Air, and it seems like you have to make larger physical arm motions to achieve small movements. I don't really know because I don't have one, so I'm asking you guys for advice on it if you've had experience with both.
Also, regarding Motion Plus:
1) Does it work on the PC with glovepie?
2) Does it help with controlling the wii remote on the PC? That is, does motion plus make the wii remote behave more like the MX Air?
Another bad thing about the wii remote is that it sounds like you must line of sight for it to work. THe MX Air doesn't need any line of sight and it doesn't even need to be pointing towards the receiver or TV. It's all relative motion, and it's awesome.
Finally, how about those universal remotes like the Logitech Harmony remotes? Do those have air-mouse features? That is, can you wave your arm around with those to control the mouse, or do you move the mouse using d-pad buttons? If it's the latter, that's no good. I was wondering if the Harmony remotes have the same technology inside is as the MX Air, but I can't tell from the stuff I've read online. I doubt it. Otherwise, it would be the perfect remote, because it has the airmouse ability, along with a D-pad, plus a bunch of other buttons.
The perfect remote in my opinion would be simply an MX Air with a D-pad. I bring all this up because I haven't seen good detailed discussions about remotes here yet.
