Hutch Wrote:Works with no CD in drive and image unmounted.
Works with no CD in drive and image mounted.
Doesn't work with CD in drive.
Also getting a script failed error on start on RecentlyAdded.py
CD or DVD ?
DVD-R in a LG GGC-H20L Bluray drive.
ls -l "/volumes/The Usual Suspects (1995)"
total 9145848
-rwxrwxrwx@ 1 htpc staff 917857 Dec 9 2009 The Usual Suspects.1995.720p.dca-6ch-fanart.jpg
-rwxrwxrwx@ 1 htpc staff 4679679008 Nov 17 2009 The Usual Suspects.1995.720p.dca-6ch.mkv
-rwxrwxrwx@ 1 htpc staff 7837 Mar 31 2010 The Usual Suspects.1995.720p.dca-6ch.nfo
-rwxrwxrwx@ 1 htpc staff 7813 Dec 9 2009 movie.nfo
-rwxrwxrwx@ 1 htpc staff 283908 Dec 9 2009 movie.tbn
-rwxrwxrwx@ 1 htpc staff 283908 Dec 9 2009 poster.tbn
Testing beta 2 nightly now.
what setting did you use to make the disk image.
Just disk utility to create the .iso, but the .iso mounted isn't the problem. It seems to be when the DVD is in the drive.
Hutch Wrote:Just disk utility to create the .iso, but the .iso mounted isn't the problem. It seems to be when the DVD is in the drive.
yes but I would need the disk image to make a DVD
That disk image is what 4GB's. I can PM a private ftp site for upload.
davilla Wrote:yes but I would need the disk image to make a DVD That disk image is what 4GB's. I can PM a private ftp site for upload.
Do you *really* need it? :/
Beta2 nightly same problem.
http://pastie.org/1194847
Let me diddle and see if I can reproduce locally.
davilla Wrote:Let me diddle and see if I can reproduce locally.
Alrite, lemme know!
Can you take you disk image, remove the mkv, then zip it up. That would make it much, much smaller. See PM for ftp site.
davilla Wrote:Can you take you disk image, remove the mkv, then zip it up. That would make it much, much smaller. See PM for ftp site.
How do you remove files from a .cdr? I tried mounting the image, then removing the file, but the size doesnt change.
Hutch Wrote:How do you remove files from a .cdr? I tried mounting the image, then removing the file, but the size doesnt change.
grrr, maybe make a new image, copy the files (less the mkv) over.
davilla Wrote:grrr, maybe make a new image, copy the files (less the mkv) over.
Ripped it on windows PC to .iso. Removed file from .iso. Made new .iso from fileset.
File uploaded. Should be 14,569,472bytes.
MD5: 365bf2b3b991595c54781f2b128fd0ab
I emailed you when file upload was at 50%.
