Hi all,
When I try to quit XBMC, it freezes, been happening for a while. Not sure what the issue is - log below. Any help would be much appreciated
http://pastie.org/1194737
Hutch Wrote:Hi all,
Now you went and cut xbmc.log so we can't see those important details at the beginning. Let's see those too please.
davilla Wrote:Now you went and cut xbmc.log so we can't see those important details at the beginning. Let's see those too please.
Woops. Updated the pastie link.
Hutch Wrote:Woops. Updated the pastie link.
SVN:34283, did you self build this ?
What's in your DVD drive ? Looks like it was in there at XBMC startup too.
davilla Wrote:SVN:34283, did you self build this ?
Downloaded from sshcs, but was also having the problem in the latest Camelot official release from xbmc.org
Also, nothing in the DVD drive.
Hutch Wrote:Downloaded from sshcs, but was also having the problem in the latest Camelot official release from xbmc.org
xbmc.log says different
maybe a disk image mounted ?
"ls -l /Volumes"
Quote:23:13:56 T:2689586400 M:320008192 NOTICE: start dvd mediatype detection
23:13:56 T:2953961472 M:320000000 DEBUG: thread start, auto delete: 0
23:13:56 T:2953961472 M:320000000 DEBUG: Compiled with libcdio Version 0.81
23:13:56 T:2689586400 M:319995904 NOTICE: initializing playlistplayer
23:13:56 T:2689586400 M:319995904 NOTICE: DONE initializing playlistplayer
23:13:56 T:2689586400 M:319995904 DEBUG: DPMS: supported power-saving modes: OFF STANDBY
23:13:56 T:2953961472 M:319983616 DEBUG: Drive closed media present, remounting...
23:13:56 T:2953961472 M:319979520 INFO: Detecting DVD-ROM media filesystem...
23:13:56 T:2953961472 M:319967232 INFO: CD Analysis Report
23:13:56 T:2953961472 M:319967232 INFO: __________________________________
23:13:56 T:2953961472 M:319967232 INFO: CD-ROM with ISO 9660 filesystem
23:13:56 T:2953961472 M:319967232 INFO: ISO 9660: -45301 blocks, label `'
Yea, was a mounted image. Removed now.
Hutch Wrote:Yea, was a mounted image. Removed now.
I'd like more info about that mounted image. It seems to have uncovered a bug.
Sure, what do you want to know?
Hutch Wrote:Sure, what do you want to know?
Well for starter, what is it, where did it come from. Can I have it
Mounted image of The Usual Suspects that I ripped. Probably too big to send you.
Hutch Wrote:Mounted image of The Usual Suspects that I ripped. Probably too big to send you.
Humm, so iso of a DVD rip ? That should have detected correctly. Is it a real DVD iso. The log says not.
It was actually mounted AND in the drive (I thought it wasn't in there since eject didn't work). So that may explain the anomaly. Sorry for the confusion.
Is that what was causing the freezing though? If so, why?
Hutch Wrote:It was actually mounted AND in the drive (I thought it wasn't in there since eject didn't work). So that may explain the anomaly. Sorry for the confusion.
If you look at xbmc.log, there lot's of info about "DVD-ROM media filesystem", I think something got stuck running.
If you want to try something. Remount the image and see if the same thing happend. If not try with image and DVD in.
Works with no CD in drive and image unmounted.
Works with no CD in drive and image mounted.
Doesn't work with CD in drive.
Also getting a script failed error on start on RecentlyAdded.py
