I was wondering what is the performance of XBMC with XVID@L5 files 720p and if those play can be played without problem as they do on XBox
I would also wonder why I bothered putting a CrystalHD but that is another issue
interceptor121 Wrote:I was wondering what is the performance of XBMC with XVID@L5 files 720p and if those play can be played without problem as they do on XBox
You know the drill, xbmc.log. dmesg and sample of the video content.
The bcm70015 can handle h264 part 2 which is found in xvid but that's not enabled and will not be enabled for Dharma. I have zero xvid files and cannot do adequate testing to enable this for Dharma.
XBMC plays it with ffmpeg4 and it does just fine
The file has probably just 2 bframes max so it actually does great
Codec info reports little dropped frames even if vcpu peaks at 65%
Very good
