Full Version: Transparency! v3.11.7 for xbmc dharma 10.1
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29
ronie Wrote:it's in custom_DialogFavourites.xml.
shouldn't be too hard to figure out how to add more items :-)
Thanks again.. hope your weekend is going well.
I'm sorry if this has been asked/mentioned.
I was wondering if you could change it to where either:
sets do not show "dvd' or "bluray" on the folder image OR
if they are all hd, have it say "bluray"
i hope this makes sense.
wonslung Wrote:I'm sorry if this has been asked/mentioned.
only a dozen times. ;-)
http://forum.xbmc.org/showthread.php?tid=90862
ronie Wrote:only a dozen times. ;-)
hehe, sorry, i was so busy trying to find out how to set thumbs for them that i somehow missed that....i guess sets is a pretty new thing eh?
Anyways, if i haven't already said it, i am in love with Transparency!
I use it on 5 xbmc machines in my house and all the family members absolutely love it too.
Thanks ronie!
Don't know if this has been posted, but the option to cycle through extrafanart does not work if you have a fanart.jpg in the movie's folder. Once you delete that jpg, the skin will cycle through the extras instead. I don't want to have to do that as I use other skins that require the fanart.jpg to be there.
Ideally, transparency should cycle between the extrafanart dir and the fanart.jpg in the movie folder if it finds both and the option is enabled.
Thanks for the great skin!
djvj Wrote:Don't know if this has been posted, but the option to cycle through extrafanart does not work if you have a fanart.jpg in the movie's folder. Once you delete that jpg, the skin will cycle through the extras instead. I don't want to have to do that as I use other skins that require the fanart.jpg to be there.
hmmm weird, never seen that....and i have locally stored fanart as well.
extrafanart is displayed 'on top' of the regular fanart...so what you describe should not be happening.
is this in filemode or library mode.
Library mode, using any view style, I typically use Slide. Using Transparency v3.11.1 and XBMC 10.0 r35647 (Official windows release from Dec 17,2010)
My movies are laid out like so:
Movies\Hot Fuzz (2007)\
Hot Fuzz (2007).mkv
Hot Fuzz (2007)-trailer.mp4
movie.nfo
movie.tbn
Movies\Hot Fuzz (2007)\extrafanart\
Basically I scrape using ember, which creates the extrathumbs folder with the thumb#.jpg (which are actually fanart pics). Then I rename the folder extrathumbs to extrafanart.
nothing wrong with your setup, mine's basically the same.
i had another look at the code and tested it myself once more, but i can't reproduce.
i assume you've tried the obvious (restart xbmc when having weird issues to see if they go away)...
you're running the official addon version ?
didn't make any modifications ?
don't accidentally have two copies of T! in your addons folder ?
i'm running out of ideas..so a Debug Log would be my last resort.
Yea, running the version pulled from the add-on scripts built into xbmc dharma. I restart xbmc constantly as it's on my gaming pc, so I never keep it running. Once my daughter is done watching music vids, I'll get you a log. Now that you say it works fine for you, I wasn't sure if it works with my setup for anyone, I'll test some things to see if I can figure anything more out.
If my movie dir gets scraped before I renamed the extrathumbs folder to extrafanart, would that affect this? Does naming of the jpgs in the extrafanart dir matter, or does it just grab anything labeled jpg?
Hello,
I have activated the mythbox plugin and I noticed that the guide menu it shows a little too high whereas the line should be above the text, not over, as seen in the attached pic.
Is this a skin correction that could be done or is it a matter of mythbox programing? Image
I can not see similar problem under another skin.
Angi321 Wrote:Hello,
thanx, should be fixed in T! svn now.
I love this skin.
One comment would be that when I go to info in movies (where cast, get thumbs is etc) if the plot text is too long there is an up, down and '+' to enlarge. If go into the enlarge/magnify then the remote back button wont work-however, the escape button will work on my keyboad.
stiggs Wrote:I love this skin.
it's a xbmc bug:
http://trac.xbmc.org/ticket/11199
i'll add a 'close' button to this window for now.
ronie Wrote:it's a xbmc bug:
Oh thanks Ronie, I see you noticed that problem before. it's a bit of a stretch to reach over for the wireless keyboard to skip it Big Grin
Just noticed my Transparency SVN updated to 920. I can no longer access the Movies library screen. I can get there from the TV Shows if I go to top level in Library and back into Movies, but not from the Home screen at all. Cannot bring up submenus from the Movies menu either. Changing to another skin works, but not in 920.
This is on my office machine, XBMC Dharma, Ubuntu 10.04 Lucid. Oddly, the bedroom media center running XBMC Live is not affected.
Did something get broken?
