djvj Wrote:Don't know if this has been posted, but the option to cycle through extrafanart does not work if you have a fanart.jpg in the movie's folder. Once you delete that jpg, the skin will cycle through the extras instead. I don't want to have to do that as I use other skins that require the fanart.jpg to be there.
Ideally, transparency should cycle between the extrafanart dir and the fanart.jpg in the movie folder if it finds both and the option is enabled.
Thanks for the great skin!
The same problem here. Anyone else having this issue? Updated to r920 (from something around r898), prior to that no problem at all.
Thx for this marvellous skin!
cu
That happened to me when i updated and didnt have Cinema Experience addon. Go to settings - skin settings - scripts - and make sure Integrate Cinema Experience in Home Movie Menu Button is DISABLED.
Can this skin support auto update movies/TV series when new items appear?
Bjur Wrote:Can this skin support auto update movies/TV series when new items appear?
What?
I haven't heard any skin that does that.. but some plugin's do, and Transparency! has support for plugins.
EclipseGT Wrote:That happened to me when i updated and didnt have Cinema Experience addon. Go to settings - skin settings - scripts - and make sure Integrate Cinema Experience in Home Movie Menu Button is DISABLED.
That option is not even on my skin. Only have Home Theater Experience (which I don't even have, so it is disabled). Using v3.11.1 installed from the addons script.
davedorm Wrote:Just noticed my Transparency SVN updated to 920. I can no longer access the Movies library screen. I can get there from the TV Shows if I go to top level in Library and back into Movies, but not from the Home screen at all. Cannot bring up submenus from the Movies menu either. Changing to another skin works, but not in 920.
This is on my office machine, XBMC Dharma, Ubuntu 10.04 Lucid. Oddly, the bedroom media center running XBMC Live is not affected.
Did something get broken?
tPe666 Wrote:The same problem here. Anyone else having this issue? Updated to r920 (from something around r898), prior to that no problem at all.
cu
is this still an issue for you?
if so, please post a
Debug Log
if not, how did you fix it?
this option should be disabled by default, so i don't quite understand why some of you are experiencing difficulties.
would like to sort this one out, so any additional info is more than welcome!
PatK Wrote:I haven't heard any skin that does that.. but some plugin's do, and Transparency! has support for plugins.
Sorry my late answer. What plugin do you recommend then
Any idea when a new release will be coming out? Love the changes in the T! SVN, using on my test computer with nightlys. But I would prefer to use current releases with all of my main units.
Tight_wad Wrote:Any idea when a new release will be coming out? Love the changes in the T! SVN, using on my test computer with nightlys. But I would prefer to use current releases with all of my main units.
the next stable will mostly be a bug fix release.
not all new features currently available in the svn version will make it into the next stable.
some of the new features are simply not compatible with dharma, while others need more testing before i'm confident enough to backport them.
i'm aiming for a release next week, but don't take my word for it.
The clearart script isn't working for me. I'm assuming because I'm running openelec? Please advise.
Ronald Pagan Wrote:The clearart script isn't working for me. I'm assuming because I'm running openelec? Please advise.
sorry, i've never heard of a 'clearart script' ?
i'm sure it'll have it's own support thread, so you could ask for help there
and be sure to include a
Debug Log when you do. :-)
or, you can ask for help on the openelec forum, i've noticed this message is posted there:
Quote:Please provide any reports of misbehaving addons that are installed through the official XBMC repo. Since OpenELEC is distributed with Python 2.6, rather than the Python 2.4 that is shipped with XBMC, this can cause some problems.
Sorry should have been 'clearer.' There is a script under the Scripts section of the skin options to download TV logos and the like. It used to work fine for me under a regulation xbmc live install. Now when I run it, it finds the TV shows but doesn't download any files. Just wanted to clear up that this is an issue on my end and not with the skin.
