kossatzd Wrote:But all of the sudden, coming from the Home Screen, clicking on either Videos, Movies or TV Shows all end up going to "file mode" i believe it's called. It used to be that when I clicked on Videos, it'd go to file mode so I can quickly pick one of my playlists, and if I clicked on Movies, it'd go straight to the movies and tv shows to tv shows.
I am experiencing the same behavior on yesterday's git version of XBMC and Transparency! 3.11.5. After starting XBMC, if I choose "Videos", it opens up the menu where I can choose from "Movies", "TV Shows", "Files", etc. It used to go straight to the "Files" mode. Then, if I return to the home menu and choose e.g. "TV Shows", it opens "TV Shows" mode correctly, but then when I return to the home menu again and pick "Videos", it opens up in "TV Shows" mode. It behaves similarly for "Movies" (pick "Movies" from home menu -> opens "Movies" mode correctly -> go back to home menu -> pick "Videos" -> opens up "Movies" mode).
And one more thing, some time ago I could choose a "default folder" under "Files" so that it opened up when I chose "Videos" from the home menu. Though I don't know whether this option is not available in the recent XBMC builds or just in Transparency!.
Kempniu Wrote:I am experiencing the same behavior on yesterday's git version of XBMC and Transparency! 3.11.5.
T! 3.11.5 is only compatible with xbmc dharma 10.0 / 10.1
if you run a nightly build of xbmc, please use the
svn version of Transparency!
Kempniu Wrote:And one more thing, some time ago I could choose a "default folder" under "Files" so that it opened up when I chose "Videos" from the home menu. Though I don't know whether this option is not available in the recent XBMC builds or just in Transparency!.
the 'make default' option in the videolibrary has been removed in xbmc:
http://forum.xbmc.org/showthread.php?p=725609
ronie Wrote:T! 3.11.5 is only compatible with xbmc dharma 10.0 / 10.1
if you run a nightly build of xbmc, please use the svn version of Transparency!
Thanks for clearing that up, ronie. I misunderstood your response to kossatzd's question.
I've noticed one more problem (SVN version of T! and a recent git version of XBMC). Steps to reproduce:
1. Go into "Videos" mode and browse to a directory containing a movie which is not yet in the library.
2. Bring up the left side menu (I don't know its proper name
) and select "Unwatched" to only view the unwatched videos.
3. Pick "Movie Information" from the context menu.
4. An empty movie information page is displayed with the "Refresh" button grayed out. Movie information is not scraped.
If you repeat the above steps, but instead choose "All movies" in step 2, everything works fine (movie information is properly scraped or the user is asked to enter the name of the movie manually if no data is found based on filename).
Kempniu Wrote:I've noticed one more problem (SVN version of T! and a recent git version of XBMC). Steps to reproduce:
that's a xbmc issue for sure.
i suggest you report it either on trac or in the genral help forum,
so the devs can take a look at it.
ronie Wrote:that's a xbmc issue for sure.
Okay, consider it done. Thanks for your help and keep up the good work with Transparency!, you're doing a fantastic job.
Hi ronie, thanks for the great skin.
Just one question, is cd wall still in this version? It used to be in general options but I can't seem to find it.
Thanks for all your hard work.
Mr Peacock Wrote:Just one question, is cd wall still in this version? It used to be in general options but I can't seem to find it.
the option is now available on the music osd:
is it possible to put gold movie set icons in regular version instead of svn version?
OggyHr Wrote:is it possible to put gold movie set icons in regular version instead of svn version?
nope, that won't be easy.
ronie Wrote:nope, that won't be easy.
what is a gold movie set icon ?
jpf55 Wrote:what is a gold movie set icon ?
i use a gold case (instead of the dvd / blu-ray ones) for movie-sets in T! svn.
ronie Wrote:i use a gold case (instead of the dvd / blu-ray ones) for movie-sets in T! svn.
Ah yes, of course, thanks
One fast feedback for last T!svn + recent XBMC svn
Recently Added Script stop to show TVshow fanart with last T! svn update.
I get black screen for all recently added shows. Movies works well!
