Full Version: Transparency! v3.11.7 for xbmc dharma 10.1
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29
Zrino Wrote:One fast feedback for last T!svn + recent XBMC svn Smile
Recently Added Script stop to show TVshow fanart with last T! svn update.
I get black screen for all recently added shows. Movies works well!
latest T! svn doesn't use the recently added script anymore.
support is now build-in in xbmc.
if you have issues, your best bet is to post a Debug Log in this thread:
http://forum.xbmc.org/showthread.php?tid=99502
also, please please please do NOT post about svn problems in the 3.11.5 thread. :-)
there's a special svn thread here:
http://forum.xbmc.org/showthread.php?tid=83643
ronie Wrote:Transparency! - A Fanart Skin v3.11.5
for xbmc dharma 10.0 / 10.1
Stupid question alert: where is this available?
I'm looking for a zip file download, can't find any link other than to the googlecode page containing the bleeding edge. I want the latest stable.
spicemuseum Wrote:Stupid question alert: where is this available?
From first page:
Download:
Transparency! v3.11.5 is now available through the xbmc addon system:
Settings > Add-ons > Get Add-ons > XBMC.org Add-ons > Skin > Transparency!
eddiem Wrote:From first page:
Download:
Yep, that of course works.
I'm looking for a zip file of the stable, can only find the latest SVN (on GoogleCode).
spicemuseum Wrote:Yep, that of course works.
SVNs are not available through addons, only stable and 3.11.5 is a stable
spicemuseum Wrote:I'm looking for a zip file of the stable
here you go:
http://mirrors.xbmc.org/addons/dharma/sk...nsparency/
ronie Wrote:here you go:
Nice one, thanks Ronie.
How do I find out which version # of Transparency I have installed? It's not listed in the credits.
What is "svn version" of the skin, and how do I get it?
Eklar Wrote:How do I find out which version # of Transparency I have installed? It's not listed in the credits.
Go to Settings>System Info
jpf55 Wrote:Go to Settings>System Info
Thanks! I have 3.11.5, so I guess the skin updates automatically.
Hello Ronnie,
I have been using SVN's for the past while and had modded a few of my own images in the \media folder and some of its subfolders. Now with 3.11.5 and the packed textures, is there a simple way that I can replace those few default images with my modded files, without having to get all of the media images from the SVN, and then risking some incompatibilities with the release version? (I can't use the SVN itself anymore since I'm still using DSPlayer and it's based on an older Dharma compatible trunk...)
The REAL Joe
therealjoeblow Wrote:Hello Ronnie,
The REAL Joe
there's a dharma branch on T! svn.
if you checkout the images from there,
you should be pretty safe.
Thanks, I'll give that a try. I'm guessing there's no way for me just to put my own modded images into some magic folder structure and have those few override what's in textures.xbt?
therealjoeblow Wrote:Thanks, I'll give that a try. I'm guessing there's no way for me just to put my own modded images into some magic folder structure and have those few override what's in textures.xbt?
nope, xbmc first checks Textures.xbt for images,
if they're not available there, it'll look for images outside the textures file.
dupe
