Full Version: Transparency! v3.11.7 for xbmc dharma 10.1
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29
This weekend I had a look at he movies and music background at the home screen. I added a small amount of shadow around the edge thinking it would be cooler, and then I noticed that the movie fanart didn't match the home screen theater "window". I haven't seen it before, but the left top and bottom and the right bottom corner have small black spots not covered by the fanart.
It's impossible to see with dark fanarts, and still hard to see with bright ones.
No big deal of course, just letting you know if you hadn't noticed.
hadn't noticed, but do now. :-)
thanx for the heads-up!
Hi Ronie, love the look of this skin and was wondering if its possible to install without using the in-XBMC menu option (eg extract the folder to my XBMC install somewhere)?
kitsunegari Wrote:Hi Ronie, love the look of this skin and was wondering if its possible to install without using the in-XBMC menu option (eg extract the folder to my XBMC install somewhere)?
yes, unzip it to the addons folder.
have a look out our wiki to figure out the exact location on your system.
Thanks, I got it working. Quite a lot of tweaking to do, but am loving the interface so far.
Hi Ronnie,
Can you please tell me how to get the uncompressed textures for 3.11.7? If I download the SVN I'll get the latest version not compatible with Dharma, is that right? I need the textures for this version because I have a few of my own customized graphics that I'd like to use (mostly clear case covers instead of the ones with the Bluray/DVD etc colored headers)
thanks
The REAL Joe
therealjoeblow Wrote:Hi Ronnie,
thanks
The REAL Joe
there's a dharma branch on T! svn as well.
ronie Wrote:there's a dharma branch on T! svn as well.
Thank you, I found that now.
Much appreciated,
The REAL Joe
Hi Ronie!
Today I peddle through visual customization of music and I noticed when I turn on Album icon background
and animated background album icon background starts zoom & pan like it should but shadow net of albums remain still/frozen in his pattern!!!
Regards...
Zrino Wrote:Hi Ronie!
thanx, is this on dharma?
if i test on pre-eden with T! svn it works fine
Yes, Dharma
Zrino Wrote:Yes, Dharma
ok, it should be fixed in svn for pre-eden then.
in movie library mode how do I change the quality of the trailers, they seem to play in 720p default and buffer several times during playback, is there a way to lower the quality to 480p somehow?
nooz Wrote:in movie library mode how do I change the quality of the trailers, they seem to play in 720p default and buffer several times during playback, is there a way to lower the quality to 480p somehow?
your question is not skin related, so i can't help you.
for the same reason, your previous post was moved here:
http://forum.xbmc.org/showthread.php?tid=115471
ronie Wrote:ah, i see.
could it be that you have more than 20 favourites?
only the first 20 will be listed when you want to add them to a menubutton.
i could increase the number of items listed, if that's the case.
Hey Ronie, did you end up increasing this limit ? Thanks.
