Full Version: Transparency! v3.11.7 for xbmc dharma 10.1
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29
Lareinette Wrote:I don't rember how I've made it so do you know how I can change movie genre icones in your skin?
if you want to change them, you need to use the svn version of Transparency!
you'll find them in the media/foldericons/genre/movies subfolder.
Lareinette Wrote:And can the movie genre fanarts be shown with your skin?
sure, there's a skin settings for that:
Skin Settings > Videos - Use genre backgrounds
ronie Wrote:if you want to change them, you need to use the svn version of Transparency!
Thanks a lot for your answer but ....
I don't understand because in the media directory of T! (C:\XBMC_Eden_11_beta_3\portable_data\addons\skin. transparency.svn\media) I don't find any default images ... just a Textures.xbt file!
I've installed Transparency! svn skin by add-on menu of XBMC ....
Lareinette Wrote:Thanks a lot for your answer but ....
you need to get the svn version from here:
http://forum.xbmc.org/showthread.php?tid=83643
Hi there!
First of all, thank you for developing T! for me it's the best skin. And now my question...
I've enabled the script "home theater experience" i can see the button in the info menu. But when i hit it, nothing happends... just get back to the slide film menu. I've read the home theater experience forum, the wiki, the diferents post....
I know i have to setup the script before using it, the problem is i'm not able to find the scripts configuration menu. Or is there no menu to configure this stuff?
Sorry if it's too silly...
thank you people!
ronie Wrote:you need to get the svn version from here:
Ok! It works fine now! This skin is perfect! Thanks a lot .....
