2010-10-04, 15:46
Hi all,
I decide to write this post after my attempt to install XBMCLive on my new AsRock box in order to collect information on issues and how to fix them and helping other people with same issues on ASROCK box.
I have to say that i am an old XBMC user and use to have the original XBOX (and i was very happy) until i got the ASROCK.
Issues i have after the installation of the Xbmcfreak LiveCD 10.00 beta2 T3.
1. Remote not working. FIXED
2. Fixing the audio issue. FIXED
4. Wi-Fi is not working.
Any help is much appreciated !!!
Alexis
Remote doesn’t work out of the box, you need to install the latest drivers for ubuntu 10.04 from Asrock.
Install wget to download the driver
* apt-get install wget
downloaded it here:
* wget ‘ftp://174.142.97.10/drivers/Nettop/Ubunt...32-23.zip’
Extract and install
* unzip ‘IR(10.04)kernel2.6.32-23.zip’
* cd lirc-nct677x-1.0.4-buntu10.04_kernel2.6.32-23/
* dpkg -i lirc-nct677x-1.0.4-ubuntu10.04_kernel2.6.32-23.deb
* Choose Nuvoton Transceivers/Remotes from the list
* Choose None for IR transmitters
Reboot the device.
* shutdown -r now
That’s it , now the remote should work when the menu’s come up.
downloaded it here:
Extract and install
Reboot the device.
* shutdown -r now
udo wget http://pastebin.com/download.php?i=f5f9654bb -O /etc/asound.conf
sudo wget http://pastebin.com/download.php?i=f2e38265 -O /usr/share/alsa/cards/HDA-Intel.conf
then change both audio output devices to "hdmi". worked to me.
thanks to Reolio who posted them here - http://forum.xbmc.org/showthread.php?tid=74778
3. Choppy HD (mkv) sudo wget http://pastebin.com/download.php?i=f2e38265 -O /usr/share/alsa/cards/HDA-Intel.conf
I have tried this with no luck. WiFi after reboot is not connecting
http://forum.xbmc.org/showpost.php?p=468527&postcount=7
Alexis
