2012-02-12, 16:28
2012-03-05, 03:56
ruuk Wrote:Well, I think that is outside the scope of what I'm trying to do with this app. Personally, though I've thought about it, I have no immediate plans to write an app for more general Facebook stuff.
Hi Ruuk
Haven't you changed your mind? I know that XBMC is a MEDIA Center and not a general purpose PC... but it would be great to be able to see your friend's posts while listening to your favorite music from the comfort of your couch when coming back from work
In any case, thanks for the work so far. The app is great
Kr
2012-03-06, 01:59
Maxi Wrote:Hi Ruuk
Kr
I've got something coming up you might like... (ooohhh mysterious)
2012-03-07, 04:36
ruuk Wrote:I've got something coming up you might like... (ooohhh mysterious)Great !!!
Will keep waiting for the news :-)
Maxi
2012-03-17, 21:50
Added sharing and feeds for ShareSocial
Download v0.6.5 zip
ShareSocial thread - go here for info about the new features.
Download v0.6.5 zip
2012-03-25, 07:35
edit as I posted in the sharesocial thread
2012-03-31, 14:11
Just installed this and login doesn't work. Verified email and password several times.
I do get a "unrecognized device" notification on Facebook, but it still doesn't work after I've allowed it. I currently do not have login approval enabled on Facebook.
Login page loading seems to hang on either "submitting form" or "processing data".
After I cancel it, I get a "failed to get new token" error message.
Any ideas?
Any ideas?
2012-03-31, 20:30
(2012-03-31, 14:11)Cthugha Wrote: [ -> ]Just installed this and login doesn't work. Verified email and password several times.
Any ideas?
I've just added the ability to disable the auto-login stuff when authorizing. Try disabling that and see if you can get through authorization, or at least get more information. In any case it would be helpful if you could get me your xbmc.log.
Also if you have 'Login Notifications' enabled, try disabling that. I think you can re-enable it after the authorization. This has helped someone else in the past.
Get the new version here:
http://facebook-media.googlecode.com/fil...-0.6.6.zip
2012-04-02, 20:55
since you brought me in the picture..
stop slackin' around and get that caching done already
I can't access image likes and comments.. the error is : 'NoneType' object has no attribute 'get'
2012-04-02, 22:39
(2012-04-02, 20:55)macf1an Wrote: [ -> ]since you brought me in the picture..
You can't access any or can't access some?
2012-04-02, 23:41
(2012-04-02, 22:39)ruuk Wrote: [ -> ](2012-04-02, 20:55)macf1an Wrote: [ -> ]since you brought me in the picture..
Nevermind, I'm getting the same error. Looking into it.
2012-04-03, 00:40
Fixed.
Get it here:
http://facebook-media.googlecode.com/fil...-0.6.7.zip
2012-04-04, 01:32
(2012-03-31, 20:30)ruuk Wrote: [ -> ]I've just added the ability to disable the auto-login stuff when authorizing. Try disabling that and see if you can get through authorization, or at least get more information. In any case it would be helpful if you could get me your xbmc.log.
Tried again with updated v0.6.7. Same problem... Tested with auto-login disabled. Stuck on "processing data"...
Login notifications disabled. Secure browsing enabled though (and I'd like to keep it on).
Where can I find the xbmc.log?
2012-04-04, 02:32
(2012-04-04, 01:32)Cthugha Wrote: [ -> ](2012-03-31, 20:30)ruuk Wrote: [ -> ]I've just added the ability to disable the auto-login stuff when authorizing. Try disabling that and see if you can get through authorization, or at least get more information. In any case it would be helpful if you could get me your xbmc.log.
Sounds like there is probably some sort of error happening. A log would be great.
Where to find your log:
http://wiki.xbmc.org/index.php?title=Log_file
2012-04-04, 20:12
(2012-04-04, 02:32)ruuk Wrote: [ -> ](2012-04-04, 01:32)Cthugha Wrote: [ -> ](2012-03-31, 20:30)ruuk Wrote: [ -> ]I've just added the ability to disable the auto-login stuff when authorizing. Try disabling that and see if you can get through authorization, or at least get more information. In any case it would be helpful if you could get me your xbmc.log.
Link to log sent as PM (I hope that's ok).
