I tried that and getting the Token authorization fail error everytime.
I tried with 4 digit code and with 3x4=12 digit code.
The device I'm trying to get the code from is on the same LAN network and both (the raspberry and my desktop computer) are using the same WAN (external real) IP trough a router.
EDIT: I forgot to tell that when the simple page from your server is loaded (where the codes are) I got strange message at the begining of the page.
Quote:
Authorization Complete
Authorization Failed!
Reason: Unknown
You may still follow the instructions below to get debug info written to the XBMC log.
You may now click OK on the XBMC dialog and enter this code: xxxx
If the previous code does not work, or your browser is behind a different IP than your XBMC machine,
enter this pin (requires Facebook Media 0.8.0 or above): xxxx-xxxx-xxxx
Version 0.8.4
Changes:
- Simplified authentication
On my
REPO.
This the removes the whole pin entry process. Please let me know if you have problems with this new method.
(2013-09-02, 16:45)julianstefanov Wrote: [ -> ]I tried that and getting the Token authorization fail error everytime.
Try the new version. It should work. Let me know.
0.8.4 Working like a charm!
Thanks alot for your fast reply and update ruuk! I appriciate it.
Well, unfortunately for me the script does not work again probably something with the encoding was previously a similar problem but the update has helped.
LOG
http://pastebin.com/dNr374dE
I installed addon version 0.8.4, but the authentication process fails with message "no form matching nr 0". I did everything as advised, but after authorizing the plugin and hiting okay, the error message above appeares.
same for me "no form matching nr 0" hitting ok brings me back to the program addons...
I can confirm the error. I imagine the login page has changed. I'll fix it as soon as I have time.
Just an update to let you all know I'm working on a fix. At the moment it's being difficult as I don't know why something is behaving the way it is. I'm sure I'll figure it out eventually. Either that or I'll get so frustrated I'll just give up on the addon entirely
Maintaining this addon is making me hate Facebook
Version 0.8.5
Changes:
- Fixed a bug generating the error "no form matching nr 0" caused by a redirect page being set to http instead of https when 'Secure Browsing' is enabled in facebook
On my
REPO.
This should fix the recent errors. In the end, the only change to the code was one addition of the letter 's'
Hi, just wanted to test your plugin but I can't authorize. I'm using newest version.
http://pastebin.com/365XAY0H
Edit:
Nvm its working now. Just tried again few hours later.
XBMC running under OpenELEC on a Pi - file manager does not show a zipfile in
http://ruuks-repo.googlecode.com, although I know it is there. Any help would be appreciated! I know there is something simple I need to do.
Well I copied it to a flash drive and managed to get your new version loaded as an addon. It didn't ask for a 4 digit pin this time but when I clicked OK after getting the "Authorization Complete", XBMC said "Authorization Error - no form matching nr 0". I verified the version number and it is in fact 0.8.5.
Version 0.8.6
Changes:
- Fix for token not being properly extracted from the auth reply URL
On my
REPO.
ruuk - now authorization in 0.8.6 works for me and I can use your plugin.
It looks great!!!
Good job!.
Thank you.
Me too ruuk! All is well in 0.8.6 - many thanks! Great that you watch these threads and reply - THUMBS UP!
