I have installed the ROM launcher on the latest Dharma release. Whenever I try to configure it, it will only display my CD/DVD drives and not my C:\ folder. Anybody know why this is? I have attached a screenie that displays what I see when trying to add an EXE location in Launcher script.
Thanks in advanced guys!
i have the same prob, but theres an easy fix.. eject all dvd from drives, unmount every virtual drive and plug of usb stuff. that helps me
Unfortunately that did not work for me. I ejected all the disc, unmounted all other items and still nothing. I cannot unmount the WD CD drive (that's my HDD array.) Oh, well. I guess I'll keep on looking. Thanks for your reply however!
The fix to this problem is to go to system / file manager. Then remove any sources that you may have added. In the end it should just say Root, then profile directory, then add source.
