2010-10-05, 23:33
I updated my year-old opensuse 11.1 Zotac ION htpc to XBMC svn 34475 and have everything working nicely except for videos with DTS audio. There previously was an option to enable stereo downmixing, which worked fine. My speaker system does not handle DTS.
This new version no longer has an option to enable downmixing, but I'm assuming that it knows to downmix if the Speaker Configuration is set to 2.0 and the 'AC3 Capable' and 'DTS Capable' options are unchecked.
I am not using HDMI output, and I get audio out the analog and digital/coax ports just fine for any video that does not have DTS audio. Anything with DTS is silent, no audio at all.
My configure string was: and get the same results regardless of which output device I use. All IEC958 sources are unmuted in alsamixer.
My videos are MythTV HDHomerun HDTV captures from TV cable, most with AC3 audio. When I check the audio track in the OSD, all the ones that play fine are AC3, and all the ones that have no audio are DTS. Both mplayer and vlc play the videos with DTS perfectly. Before the XBMC upgrade on this box, this problem didn't happen. So I'm trying to figure out what change I need to make to get DTS downmixing in XBMC working again.
./configure --enable-mid --disable-debug --disable-pulse --prefix=/usr
