Hi
i have pin87's USB Ubuntu Image running on a USB Stick on my Apple TV.
Basically everything runs quite smooth , except when i play 720p TV Series on my Apple TV. I get a lot of dropped frames. within 1 min it 's already at 50-60 dropped frames.
here is the log :
http://pastebin.com/zdH5Uwhr
and this is the xbmc version i'm running :
Starting XBMC, Platform: Linux (Ubuntu 8.04.4 LTS, 2.6.24-28-generic i686). Built on Sep 14 2010 (SVN:33778)
Thanks for any help, i appreciate that.
see what a/v is doing. and you might turn off ExtractThumb, that sucks CPU when it's doing it at the same time as playing video.
and you might fix your custom audio device
Quote:ERROR: Initialize - failed to open custom device plughw:0,3:AES0=0x6,AES1=0x82,AES2=0x0,AES3=0x2 (error:No such file or directory), retry with default plughw:0,3
thumb deactivated, sound fixed
still stuttering though.
any other advice ?
It starts after about 15sec's of every TV series in 720p
it's not dropping frames anymore, but stuttering as hell.
here 's a new pastebin:
http://pastebin.com/UBeJXv2a
Can you turn sync playback to display off.
Can you also try to play the file from a local harddrive.
sync playback to display is turned off
no changes except that the dropped frames rise again , but stuttering remains.
Shouldn't be a problem of the local HDD; i play 1080p movies without a problem from the network.
what is a/v is doing, does it blip when you get a stutter.
sorry for my ignorance , but what does that mean ?
DrPepper Wrote:sorry for my obnoxiousness , but what does that mean ?
'o' on keyboard brings up the decoder OSD. a/v/ is the audio/video sync.
when i turn on the a/v sync, there way less drops, but the stuttering remains.
what i can see is that the the frame rate varies from 24 to 30 it's jumping.
CPU0 is at 35 % a/v shows 1.600 or so. and rising. now after few minutes it's at 3.200 and still rising
having a/v sync off, i get constant drops and the a/v shows around 0.500 after 30sec and rising
fps jumping up and down as well
were you able to reproduce the error ?
Are you experiencing it as well
Can you try with render method set to basic shaders(arb).
same problem. no difference.
