Full Version: [LIVE] Installation problems
Hi
I have installed XBMC on an eBox-3310 from an USB pen, seemingly without any problems, but when I boot, I get the logo and after a short while a mouse cursor, which changes to an X, where after the gui disappears and I end up in a Ubuntu commandline and is prompted for username and password.
I can start the window manager, but when I try to start XBMC from there, I again gets the logo, and after a short while returns to the window manager.
The crash log looks like this (I cannot find anything wrong here) :
############## XBMC CRASH LOG ###############
################ SYSTEM INFO ################
Date: Wed Oct  6 00:58:50 CEST 2010
XBMC Options:
Arch: i586
Kernel: Linux 2.6.31-16-generic #53-Ubuntu SMP Tue Dec 8 04:01:29 UTC 2009
Release:
    Distributor ID:    Ubuntu
    Description:    Ubuntu 9.10
    Release:    9.10
    Codename:    karmic
############## END SYSTEM INFO ##############
############### STACK TRACE #################
=====>  Core file: /home/mediasys/core
############# END STACK TRACE ###############
################# LOG FILE ##################
00:58:45 T:3079247728 M:451538944  NOTICE: -----------------------------------------------------------------------
00:58:45 T:3079247728 M:451538944  NOTICE: Starting XBMC, Platform: GNU/Linux.  Built on Dec 24 2009 (SVN:26018)
00:58:45 T:3079247728 M:451538944  NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
00:58:45 T:3079247728 M:451538944  NOTICE: special://masterprofile/ is mapped to: /home/mediasys/.xbmc/userdata
00:58:45 T:3079247728 M:451538944  NOTICE: special://home/ is mapped to: /home/mediasys/.xbmc
00:58:45 T:3079247728 M:451538944  NOTICE: special://temp/ is mapped to: /home/mediasys/.xbmc/temp
00:58:45 T:3079247728 M:451538944  NOTICE: The executable running is: /usr/lib/xbmc/xbmc.bin
00:58:45 T:3079247728 M:451538944  NOTICE: Log File is located: /home/mediasys/.xbmc/temp/xbmc.log
00:58:45 T:3079247728 M:451141632  NOTICE: Setup SDL
00:58:45 T:3079247728 M:450379776  NOTICE: load settings...
00:58:45 T:3079247728 M:450379776  NOTICE: special://profile/ is mapped to: special://masterprofile/
00:58:45 T:3079247728 M:450379776  NOTICE: loading special://masterprofile/guisettings.xml
00:58:45 T:3079247728 M:450379776  NOTICE: Getting hardware information now...
00:58:45 T:3079247728 M:450379776  NOTICE: Checking resolution 12
00:58:45 T:3079247728 M:450379776  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
00:58:45 T:3079247728 M:450379776  NOTICE: Loaded playercorefactory configuration
00:58:45 T:3079247728 M:450379776  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
00:58:45 T:3079247728 M:450379776  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
00:58:45 T:3079247728 M:450379776  NOTICE: No advancedsettings.xml to load (special://masterprofile/advancedsettings.xml)
00:58:45 T:3079247728 M:450379776  NOTICE: Default DVD Player: dvdplayer
00:58:45 T:3079247728 M:450379776  NOTICE: Default Video Player: dvdplayer
00:58:45 T:3079247728 M:450379776  NOTICE: Default Audio Player: paplayer
00:58:45 T:3079247728 M:450379776  NOTICE: special://masterprofile/sources.xml
00:58:46 T:3079247728 M:448233472  NOTICE: Using fbConfig[1]
00:58:46 T:3079247728 M:444297216  NOTICE: GL_VENDOR = Mesa Project
00:58:46 T:3079247728 M:444297216  NOTICE: GL_RENDERER = Software Rasterizer
00:58:46 T:3079247728 M:444297216  NOTICE: GL_VERSION = 2.1 Mesa 7.6
00:58:46 T:3079247728 M:444297216  NOTICE: GL_EXTENSIONS = GL_ARB_copy_buffer GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_half_float_pixel GL_ARB_imaging GL_ARB_map_buffer_range GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_shading_language_120 GL_ARB_shadow GL_ARB_shadow_ambient GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_transpose_matrix GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_logic_op GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_convolution GL_EXT_copy_texture GL_EXT_depth_bounds_test GL_EXT_draw_range_elements GL_EXT_framebuffer_object GL_EXT_framebuffer_blit GL_EXT_fog_coord GL_EXT_gpu_program_parameters GL_EXT_histogram GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_pixels GL_EXT_paletted_texture GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_polygon_offset GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_shared_texture_palette GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_subtexture GL_EXT_texture GL_EXT_texture3D GL_EXT_texture_edge_clamp GL_EXT_texture_env_add GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_swizzle GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_3DFX_texture_compression_FXT1 GL_APPLE_packed_pixels GL_APPLE_vertex_array_object GL_ATI_blend_equation_separate GL_ATI_envmap_bumpmap GL_ATI_texture_env_combine3 GL_ATI_texture_mirror_once GL_ATI_fragment_shader GL_ATI_separate_stencil GL_IBM_multimode_draw_arrays GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_INGR_blend_func_separate GL_MESA_pack_invert GL_MESA_resize_buffers GL_MESA_texture_array GL_MESA_ycbcr_texture GL_MESA_window_pos GL_NV_blend_square GL_NV_fragment_program GL_NV_light_max_exponent GL_NV_point_sprite GL_NV_texture_env_combine4 GL_NV_texture_rectangle GL_NV_texgen_reflection GL_NV_vertex_program GL_NV_vertex_program1_1 GL_OES_read_format GL_SGI_color_matrix GL_SGI_color_table GL_SGI_texture_color_table GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_SUN_multi_draw_arrays
00:58:46 T:3079247728 M:444297216   ERROR: GLX: Same window as before, refreshing context
00:58:48 T:3079247728 M:441126912  NOTICE: HAL: Generating global device list
00:58:48 T:3079247728 M:441126912  NOTICE: start dvd mediatype detection
00:58:48 T:3079247728 M:441126912  NOTICE: initializing playlistplayer
00:58:48 T:3079247728 M:441126912  NOTICE: DONE initializing playlistplayer
00:58:48 T:3079247728 M:441126912  NOTICE: load default skin:[Confluence]
############### END LOG FILE ################
############ END XBMC CRASH LOG #############
Any ideas ?
Kim Foder
