Full Version: Library Import - I'm Stuck
Hi All,
Have just installed Dharma Beta 2 to give it a go and have a problem importing library files
I imported all my movies (which have single url nfo's) and then exported the library as individual files (overwriting my old ones) so I could edit some of the files to provide <set> and <sorttitle> information. That all worked well.
But when I go into Library Import it doesn't see my nfo files (also tried renaming them to xml files). It doesn't matter if i select ok on the folder, or in the folder, it just goes back to video library settings without doing any importing and I don't know what I'm doing wrong
Have looked at the wiki and searched the forums but can't find an answer
Was wondering if anyone had any ideas please?
Many thanks
Tony
Just realised if I remove each of the effected movies from the library I can simply rescan the folder and that puts them back in, so will use that method but will take a lot longer
