Hi All,
Just using XBMC on my ATV for the first time and it's great - almost got everything set up, and just added our family photos folder to "Pictures" (located on a Windows network over a 802.11g connection). I can browse the photos folder (which just has sub-folders in), and the sub-folders with pictures in them get the pictures showing up in the folder thumbnail, but when I open any folder (regardless of whether it has photos and/or folders in) it hangs.
My ATV is running 3.0.1, with XBMC 9.11 and Launcher 3.2.5
any thoughts?
Thanks davilla,
okay, here's the log:
23:25:24 T:2684407808 M: 36798464 NOTICE: -----------------------------------------------------------------------
23:25:24 T:2684407808 M: 36794368 NOTICE: Starting XBMC, Platform: Mac OS X. Built on Dec 23 2009 (SVN:26018)
23:25:24 T:2684407808 M: 36794368 NOTICE: special://xbmc/ is mapped to: /mnt/Scratch/Users/frontrow/Applications/XBMC.app/Contents/Resources/XBMC
23:25:24 T:2684407808 M: 36794368 NOTICE: special://masterprofile/ is mapped to: /Users/frontrow/Library/Application Support/XBMC/userdata
23:25:24 T:2684407808 M: 36794368 NOTICE: special://home/ is mapped to: /Users/frontrow/Library/Application Support/XBMC
23:25:24 T:2684407808 M: 36794368 NOTICE: special://temp/ is mapped to: /Users/frontrow/.xbmc/temp
23:25:24 T:2684407808 M: 36794368 NOTICE: The executable running is: /mnt/Scratch/Users/frontrow/Applications/XBMC.app/Contents/MacOS/XBMC
23:25:24 T:2684407808 M: 36794368 NOTICE: Log File is located: /Users/frontrow/Library/Logs/xbmc.log
23:25:24 T:2684407808 M: 36794368 NOTICE: -----------------------------------------------------------------------
23:25:24 T:2684407808 M: 36794368 NOTICE: Setup SDL
23:25:25 T:2684407808 M: 35192832 NOTICE: load settings...
23:25:25 T:2684407808 M: 35192832 NOTICE: special://profile/ is mapped to: special://masterprofile/
23:25:25 T:2684407808 M: 35192832 NOTICE: loading special://masterprofile/guisettings.xml
23:25:25 T:2684407808 M: 35192832 NOTICE: Getting hardware information now...
23:25:25 T:2684407808 M: 35192832 NOTICE: Checking resolution 12
23:25:25 T:2684407808 M: 35192832 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
23:25:25 T:2684407808 M: 35188736 NOTICE: Loaded playercorefactory configuration
23:25:25 T:2684407808 M: 35188736 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
23:25:25 T:2684407808 M: 35188736 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
23:25:25 T:2684407808 M: 35184640 NOTICE: Loaded advancedsettings.xml from special://profile/advancedsettings.xml
23:25:25 T:2684407808 M: 35184640 NOTICE: Contents of special://profile/advancedsettings.xml are...
<advancedsettings>
<skiploopfilter>8</skiploopfilter>
</advancedsettings>
23:25:25 T:2684407808 M: 35184640 NOTICE: Getting hardware information now...
23:25:25 T:2684407808 M: 35184640 NOTICE: Checking resolution 12
23:25:25 T:2684407808 M: 35184640 NOTICE: Default DVD Player: dvdplayer
23:25:25 T:2684407808 M: 35184640 NOTICE: Default Video Player: dvdplayer
23:25:25 T:2684407808 M: 35184640 NOTICE: Default Audio Player: paplayer
23:25:25 T:2684407808 M: 35184640 NOTICE: special://masterprofile/sources.xml
23:25:25 T:2684407808 M: 35180544 ERROR: Missing or invalid <name> and/or <path> in source
23:25:25 T:2684407808 M: 31002624 NOTICE: GL_VENDOR = NVIDIA Corporation
23:25:25 T:2684407808 M: 30998528 NOTICE: GL_RENDERER = NVIDIA GeForce Go 7300 OpenGL Engine
23:25:25 T:2684407808 M: 30998528 NOTICE: GL_VERSION = 1.5 NVIDIA-1.4.60
23:25:25 T:2684407808 M: 30998528 NOTICE: GL_EXTENSIONS = GL_ARB_transpose_matrix GL_ARB_vertex_program GL_ARB_vertex_blend GL_ARB_window_pos GL_ARB_shader_objects GL_ARB_vertex_shader GL_EXT_multi_draw_arrays GL_EXT_clip_volume_hint GL_EXT_rescale_normal GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_gpu_program_parameters GL_APPLE_client_storage GL_APPLE_specular_vector GL_APPLE_transform_hint GL_APPLE_packed_pixels GL_APPLE_fence GL_APPLE_vertex_array_object GL_APPLE_vertex_program_evaluators GL_APPLE_element_array GL_APPLE_flush_render GL_NV_texgen_reflection GL_NV_light_max_exponent GL_IBM_rasterpos_clip GL_SGIS_generate_mipmap GL_ARB_shading_language_100 GL_ARB_imaging GL_ARB_point_parameters GL_ARB_texture_env_crossbar GL_ARB_texture_border_clamp GL_ARB_multitexture GL_ARB_texture_env_add GL_ARB_texture_cube_map GL_ARB_texture_env_dot3 GL_ARB_multisample GL_ARB_texture_env_combine GL_ARB_texture_compression GL_ARB_texture_mirrored_repeat GL_ARB_shadow GL_ARB_depth_texture GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_occlusion_query GL_ARB_point_sprite GL_ARB_texture_non_power_of_two GL_ARB_vertex_buffer_object GL_ARB_pixel_buffer_object GL_ARB_draw_buffers GL_ARB_shader_texture_lod GL_EXT_compiled_vertex_array GL_EXT_framebuffer_object GL_EXT_texture_rectangle GL_ARB_texture_rectangle GL_EXT_texture_env_add GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_texture_lod_bias GL_EXT_abgr GL_EXT_bgra GL_EXT_stencil_wrap GL_EXT_texture_filter_anisotropic GL_EXT_secondary_color GL_EXT_blend_func_separate GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_texture_compression_s3tc GL_EXT_texture_compression_dxt1 GL_EXT_blend_equation_separate GL_EXT_texture_mirror_clamp GL_EXT_packed_depth_stencil GL_APPLE_flush_buffer_range GL_APPLE_ycbcr_422 GL_APPLE_vertex_array_range GL_APPLE_texture_range GL_APPLE_float_pixels GL_ATI_texture_float GL_ARB_texture_float GL_APPLE_pixel_buffer GL_NV_point_sprite GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_blend_square GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_fog_distance GL_NV_depth_clamp GL_NV_multisample_filter_hint GL_NV_fragment_program_option GL_NV_vertex_program2_option GL_ATI_texture_mirror_once GL_ATI_texture_env_combine3 GL_ATI_separate_stencil GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod
23:25:26 T:2684407808 M: 26951680 NOTICE: start dvd mediatype detection
23:25:26 T:2684407808 M: 26923008 NOTICE: initializing playlistplayer
23:25:26 T:2684407808 M: 26923008 NOTICE: DONE initializing playlistplayer
23:25:26 T:2684407808 M: 26923008 NOTICE: load default skin:[Confluence]
23:25:27 T:2684407808 M: 22585344 NOTICE: initialize done
23:25:27 T:2684407808 M: 22581248 NOTICE: Running the application...
23:25:27 T:2684407808 M: 22577152 NOTICE: ES: Starting event server
23:25:27 T:43364864 M: 22573056 NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
23:25:27 T:43364864 M: 22573056 NOTICE: UDP: Listening on port 9777
23:25:27 T:2684407808 M: 22568960 NOTICE: starting zeroconf publishing
23:26:44 T:43364864 M: 6676480 NOTICE: ES: Client from 127.0.0.1 timed out
The interesting part is obviously the last line, although I'm not sure if the line "
ERROR: Missing or invalid <name> and/or <path> in source" is important too??
It appears that it's not crashing at all, but instead taking a long time to time-out doing *something* before opening a folder. If I just click once and wait 60 seconds it will open the folder. If I then click on an image to view to sits there for only about 10 seconds this time before opening the image, and also adding a similar line to the log file:
23:33:15 T:43364864 M: 3178496 NOTICE: ES: Client from 127.0.0.1 timed out
Any hints from here?
Thanks again davilla,
As I'm new to this it took a little searching to find out how to get the new beta2 into my ATV, (for other novices reading this, see
http://forum.xbmc.org/showthread.php?tid=67078).
I get pretty much the same problem as before, still with the "ES: Client from 127.0.0.1 timed out" in the log from time to time, but I think now that it's had a chance to cache thumbnails and/or because I'm more aware that it's a taking-a-long-time issue rather than a hanging issue, it's at least semi-usable.
It can take a good 30 seconds to open a folder I haven't opened before - there's a downloading progress bar that appears after that and takes about 10sec, but some times there's also the ~30-second wait before that where it seems to hang.
Also moving from one photo to the next when viewing them full-screen takes consistently 10 seconds. Is this just because they're 10mp images over a wireless 802.11g network (with good signal strength)?? (about 2.5mb each). If this is the case I'll move them all to the ATV hard disk... maybe even make a script to shrink them to my TV res instead of 4000x3000 so they don't take 60GB of space needlessly on the device and don't take 18hrs to move there over the wireless connection... I guess it would make sense to be able to sync this as well to make it easy when new images are added... Is there some script/utility around already that does this sort of syncing?
Please let me know if these big delays sound "normal" for my setup, or if it seems like I must have something wrong still. Any ideas what the "ES: Client from 127.0.0.1 timed out" is referring to? (it's connecting over a Windows XP network)
Zuur Wrote:Thanks again davilla,
As I'm new to this it took a little searching to find out how to get the new beta2 into my ATV, (for other novices reading this, see http://forum.xbmc.org/showthread.php?tid=67078).
"ES: Client from 127.0.0.1 timed out" -> event server. Ignore it, that's not your problem.
