Full Version: "to spiff" correction for both turkish scrapers
beyazperde movie scraper seems broken. cause in addon.xml
library="beyazperde.xml.xml
must be one xml like
" beyazperde.xml "
and the correct xml file at
http://turkishxbmcscraper.googlecode.com/files/beyazperde.xml
and other one turkcealtyazi.org scraper ready with all necessary files at
http://turkishxbmcscraper.googlecode.com/files/altturk.zip
i try to use [zip pull] an mailing list but i'm not sure i'd success
you got the answer on the mailing list.
The scraper doesn't work at all.
Please TEST both the installation and the scraping in Beta2 before you resubmit.
Other than that, if you are using googlecode, then why not uploading the source and request an SVN pull(but this is the smallest issue now)
