2010-10-07, 23:50
Hello,
after my problem with the remote is fixed thanks to your help I'm now facing a new problem:
I'm not able to get xbmc to start automatically. I'm always getting the login screen.
First the history:
- Installed xbmc using the xbmc-live karmic/camelot image
- Had a lot of fun...
- Upgraded the distribution to 10.4
- Installed latest ppa
- Remote did not work
- installed everything needed to compile
- compiled from svn
- uninstalled xbmc, xbmc-live and xbmc-standalone
- installed my own compiled version using "make install"
With that I'm now able to start xbmc using putty (ssh/telnet from windows) with the command "xinit xbmc" (and yay remote does work again)
Just calling "xbmc" does give an error ("Error: unable to open display, FEH.py: cannot connect to X server")
I was hinted on this script to autostart:
http://trac.xbmc.org/browser/trunk/tools...ve/runXBMC
I put that script to "/etc/init.d" and did an "chmod +x filename" on it.
But it still does not autostart xbmc...
Any hints ? I do not have much expierence with linux... Is there a log I could look into to see whats going wrong with the script ?
Is it necessary to call the file "dontknow.sh" ?
Another idea I had was to reinstall xbmc, xbmc-live and xbmc standalone and then use "make install /usr" to install "over" the ppa version. Do you think that might work ?
First the history:
- compiled from svn
