2010-10-08, 20:45
I was wondering if anyone knows how to make a script that automatically installs all the common emulators in XBMC live. Essentially, it would do the following:
sudo apt-get install mednafen (and automatically say "Yes" to the install prompt)
sudo apt-get install mupen64plus
sudo apt-get install zsnes
and whatever it takes to get Gens installed (I believe this is more involved)
additionally, it would be nice if it would create a default roms directory in the xbmc home directory, for example:
/home/xbmc/roms/
from there populate the roms with subfolders for all the systems:
'n64', 'nes', 'snes', 'gba', genesis, etc
It would be great if the script did at least the first of the above, but I'm thinking this would be a really easy way for someone to jump into things and install the Launcher addon afterward. Maybe even in the future an addon that runs the script + Launcher and then sets up the arguments and roms directories automatically.
/home/xbmc/roms/
